Sunset
Sunset
I ported an old unfinished scene to BlendLuxCore.
Still needs some work, e.g. better trees, better water etc.
Maybe also some more image elements.
AMD HD 7970 GHz, Path OpenCL + Sobol (adaptive), 6min render time, around 12 Mio. tris (many particles).
Re: Sunset
nice sunset i like the mountain behind.
How much clamp for this one ?
Re: Sunset
No clamping at all.
By the way the sky and sun in the background are just a JPG on a light emitting plane.
I'll have to improve that because it makes the lighting a bit flat.
SATtva
Supporting Users
Re: Sunset
Post by SATtva »
The mix of water ripple and calm splotches is brilliant.
Luximage
Re: Sunset
Post by Luximage »
Very nice image B.Y.O.B, i like the mood and the composition.
Re: Sunset
An update.
I'm now using a cropped portion of an HDRI on the light emitting plane in the background, mixed with the JPG I had earlier, for a bit better lighting.
Still had to resort to a fake sun (coming somewhere from the left) to get a nice rim light.
Unfortunately I can't make the light emitting background plane invisible to the sun.
I need to improve the trees.
Somehow my water shaders quickly go over board.
Thanks for your comments :)
This time 8min PathOCL+Sobol, this time with clamping.
Re: Sunset
Better than previous one. but just wonder why your lighting scheme is so uncommon :?:
Re: Sunset
I try to avoid filling my GPU memory with a giant HDRI that you only see 10% of (where the camera is looking).
I should probably do it differently: Use low-resolution HDRI with transparent film and then add the backplate in compositing. However the reflection in the water would not match in that case.
Re: Sunset
understand now a bit sad :| . what is your GPU
Re: Sunset
HD 7970 GHz (3GB VRAM).
