Cold Fusion
Cold Fusion
Hi guys just want to share with you My last output with Luxcore.The scene is not complexe but used feature are a bit hard to render when mixed together.
CPU ==> I7 6700k
RENDERTIME ==> give me your opinion what do you think the render time could be
POLYCOUNT ==> 1.2K
RENDERMOD ==> Bidir
EDIT ==> Darktable (denoise)
EFFECTS ==> participating Media / dispersion / Glass2
RENDER SET ==> (deph 32-----32)
RESOLUTION ==> 2160 X 2160
NOW sale enchere is launch How many time for this ?
EDIT BLEND FILE :
Prism.blend
(599 KiB) Downloaded 667 times
Re: Cold Fusion
Looking good, a lot of details to discover.
Rendertime - if you say it's hard to render, maybe 5 hours?
Re: Cold Fusion
Sharlybg wrote: Mon Jan 29, 2018 9:20 am RENDERTIME ==> give me your opinion what do you think the render time could be
It depends a bit of about was de-noised but I would say 1 hour.
Re: Cold Fusion
B.Y.O.B. wrote: Mon Jan 29, 2018 9:27 am Looking good, a lot of details to discover.
So also need the raw output without denoise : this it
just to help you you are both faaaar from reallity ;)
Re: Cold Fusion
Really hard to say. In the past I rendered laser stuff with dispersion in 20 minutes (Classic API).
Could be either 5 minutes or 50 hours.
Re: Cold Fusion
B.Y.O.B. wrote: Mon Jan 29, 2018 10:03 am Really hard to say. In the past I rendered laser stuff with dispersion in 20 minutes (Classic API).
Do you take in count that it is a 2k render ???? now the blend is available in my first post you can try ;)
Re: Cold Fusion
B.Y.O.B. wrote: Mon Jan 29, 2018 10:03 am Could be either 5 minutes or 50 hours.
Yes, especially because it depends on the lights were done: with spot or laser lights takes 15 minutes, with light sources hidden inside the boxes and light coming out only by the tiny hole, takes 50 hours.
Re: Cold Fusion
:shock: :shock: :shock: you want say what ??? Ok i've tried with spot and maybe found a bug a "wrong spot position/rotation".
the result
Re: Cold Fusion
A 60 seconds rendering with lasers:
Check your spot light settings, the penumbra angle, etc. but laser light sources are usually better for this kind of renderings.
Re: Cold Fusion
Please can you modify my blend with right settings for spot/laser ?
just send box light in another layer and add correct light with correct setting. please really can't here.don't want to be wrong (""After 60h 23mn render mistake"")
