Hi there!
I'm a bit confused over which version I should have installed. OpenCl or without? I'm on Win10/6700K/GTX 1080 running Official Blender 2.79b. When installing LCR 2.0 OpenCl version Blender won't have any of it and throws an error (dll load failed: the specified module could not be found). The non-CL version works just fine but does this mean I miss out on GPU rendering? Also, upgrading LCR through the Blender addons panel to an experimental build seems to not work for me? Sorry for all the noob questions. Any response, in full or in part is greatly appreciated Oh, and both the Visual C++ Redistributables are installed btw.
Robonnet wrote: Fri Nov 09, 2018 12:41 pm
Hi there!
/Rob
install this: you are on a 1080 gtx so you can use opencl.
Thanks for the speedy response, Sharlybg. I tried that and Blender throws this error (attachment 1) I think I may have messed up the order in which I uninstalled the previous version of LCR? I missed this part (below) of the installation instruction. Would a re-install of Blender rectify this (if it's indeed the problem)
From the installation instruction section
If you have v2.0 installed, you will have to follow the remove steps below, then download the v2.1 release zip package, and follow the install steps on the top of this page.
To remove the addon:
Open Blender's user preferences
Search for LuxCore
Deactivate the addon (don't press remove yet)
Save the user preferences
Restart Blender
Open user preferences, navigate to the addon again
Now press the remove button
It is needed to deactivate the addon before removing it because it contains some libraries (DLLs) which can not be deleted while being loaded on some operating systems (e.g. Windows).
I've installed all the required extas now but still receiving the same error message. I'll try one last hail mary and update the display drivers. If it doesn't work I'll patiently wait for an official 2.8 realease and try it again. I appreciate the assistance guys
