Direct Light Sampling Cache errors
Asticles
Post by Asticles » Tue Nov 06, 2018 8:40 am
Hi all,
I'm having some strange artifacts with Direct Light Sampling Cache:
I've created this blend file with the error:
caching.blend
(662.84 KiB) Downloaded 2 times
Edit: Have cleaned the file.
Best regards.
Salvador Ureña
stefdln
Re: Direct Light Sampling Cache errors
Post by stefdln » Tue Nov 06, 2018 8:48 am
I guess this has been exposed inthis thread
viewtopic.php?f=4&t=705
and corrected in the latest daily build (not sure about this one)
Cheers
Asticles
Post by Asticles » Tue Nov 06, 2018 8:59 am
Thanks for your response, I've tested it with this build and the same happens.
https://github.com/LuxCoreRender/LuxCor ... tag/latest
Regards
Salvador Ureña
Post by Dade » Tue Nov 06, 2018 10:06 am
It is a different problem I'm currently investigating.
Post by B.Y.O.B. » Tue Nov 06, 2018 12:30 pm
The .blend file is missing the textures.
Post by lacilaci » Tue Nov 06, 2018 2:37 pm
Is this the, hdri/skylight cache sampling issue? Can this be solved without fiddling with warmup samples?
Asticles
Post by Asticles » Tue Nov 06, 2018 5:47 pm
Sorry, I cannot redistribute the textures.
https://www.textures.com/download/pbr0075/133109
If you want to download them, but I've cleaned the file posted above. It also makes the same artifacts but without the textures.
Regards
Salvador Ureña
Asticles
Post by Asticles » Tue Nov 06, 2018 6:02 pm
Salvador Ureña
Post by kintuX » Tue Nov 06, 2018 8:29 pm
Hope this helps ;)
1. It only happens with the Sky.
2. It gets more prominent with 'Use Ground Color'.
3. Goes away when Ground Color is set to Black, while changing Ground Albedo Color results are fine (w/o splotches).
Edit: Missing description for Albedo versions: above is Black, below is White (if in doubt, observe sky coloration). ;)
Post by Dade » Tue Nov 06, 2018 10:22 pm
Very strange, I will check: it sounds like some kind of normal-related problem (aka taking light from "down" instead of "up").
