OK so I have done some tests with tile pathopencl and the denoising result is pitch black image while on cpu working correctly.
Luxcore 2.1beta1. Can anyone recreate the problem?
Denoiser + tile PathOpencl not working
Re: Denoiser + tile PathOpencl not working
You should post a test scene or it will impossible to make any comment.sarmath wrote: Wed Oct 31, 2018 3:28 pm OK so I have done some tests with tile pathopencl and the denoising result is pitch black image while on cpu working correctly.
Test scene was sharlybg food scene and basicly any scene I throw on Tile pathopencl + denoising result in black image. Cpu tile path works ok.
This is the screenshots with the result I get with beta1 and alpha4.
It looks like a bug in BlendLuxCore: if I export the scene everything works fine inside LuxCoreUI while Blender shows a black denoised image. I have tried with TILEPATHOCL, TILEPATHCPU, PATHCPU and it happens with all of them.sarmath wrote: Thu Nov 01, 2018 3:00 am This is the screenshots with the result I get with beta1 and alpha4.
