Hey,
i'm trying a lot of different render settings in LuxCore lately and i see, that there really is a big difference between all the possible settings.
Sometimes i feel like resetting everything to default again, to get a new start from there. What do you think about a 'reset to default' button on bottom or top of the render settings panel?
BTW it's great fun to experiment with all that mighty features of LuxCore.
Thanks!
Render Settings to Default Values
Re: Render Settings to Default Values
You can right click on any setting and select "Reset to default" from the menu.
If you want to reset all config properties at once, use this script:
(paste it into a text editor in Blender and press "Run Script")
It will lead to an output like this:
import bpy
def get_members(root):
return [attr for attr in dir(root) if not callable(getattr(root, attr)) and not attr.startswith("__")]
def unset_recursive(root):
for member in get_members(root):
try:
old = getattr(root, member)
root.property_unset(member)
new = getattr(root, member)
if old != new:
print("Reset prop to default:", member, "(was: " + str(old) + ", now: " + str(new) + ")")
unset_recursive(member)
except Exception:
pass
print("---")
unset_recursive(bpy.context.scene.luxcore.config)
print("---")Code: Select all
Reset prop to default: device (was: OCL, now: CPU)
Reset prop to default: sampler (was: METROPOLIS, now: SOBOL)
Reset prop to default: seed (was: 23, now: 1)
johannes.wilde
Thanks, perfect.
That's exactly what i wanted to know. I was just to stupid to find!
