Weird gamma using spot light with bitmap
davorin
Post by davorin »
Good afternoon (o;
I am doing some simulation of user interfaces where a spot light with a bitmap cast an image onto a semitransparent glass object...
Suddenly I discovered when I used color gradients in the bitmap that the gamma is totally wrong in rendering...looks like brightness over saturation...
Original bitmap:
and rendered output (bitmap is turned 180 degrees):
Also it depends from which side the camera is looking onto....
macOS 10.3.6, i7-7700, 32GB RAM, GTX1060 6GB
Re: Weird gamm using spot light with bitmap
Have you specified the correct gamma value for the image?
How do your color management settings look like, are you using filmic?
Can you upload a testscene with all textures that shows the problem?
davorin
Post by davorin »
Tried a little with gamma settings...but higher values gets me more of the left side being dark...
color settings I didn't touch as other stuff looks normal to me...
Attached the scene...think it should contain all bitmaps..
BTW: What is best for a spot light bitmap?
Using a black background or using a transparent background?
test_scene.zip
(1.44 MiB) Downloaded 457 times
davorin
Re: Weird gamma using spot light with bitmap
Post by davorin »
This is now with a higher gamma value for the bitmap (5):
Note the fine line at the left which should be not lit...
Especially the effect can be seen with this bitmap I used originally.
The gradients around the white circles are almost flat:
You are using filmic color management.
Your image is probably completely over-exposed. Filmic has this behaviour that overexposed colors get desaturated instead of blowing out.
Also, the gamma of your image is probably 2.2, not 5, which leads to excessive banding because the 8 bit image does not have enough information.
Attached is a fixed scene where these problems are solved.
test_scene.zip
(1.44 MiB) Downloaded 437 times
wrong, default (here you can see the overexposure)
wrong, filmic
wrong, filmic
fixed, default
fixed, default
fixed, filmic
fixed, filmic
davorin
Post by davorin »
Wow..that looks great...think I have to adjust the other lamps as the cube below is now too dark (o;
many thanks
richard
Or you have to make the overall image brighter by adjusting the tonemapper scale, but in turn make the spot light darker.
By the way, I disabled automatic tonemapping, this is usally better once you know the tonemapping scale your scene needs.
And one general tip: if you use filmic, sometimes switch to default to make sure your image is not completely over-exposed.
