[LuxCore + BlendLuxCore] [v2.11] Breaking Default Behavior - ShadowColor + Light Tracing
Announcement posts of new features and API changes
Note: Only Developers can open new threads in this forum, but users are encouraged to comment and provide Feedback on the presented features.
For the v2.11 release, I unified a different behavior between BiDir and Path+Light. Unless the settings are modified, this will lead to scenes rendering different (for Path+Light) when:
  • Shadow color is being used (i.e. it is not black)
  • Light-tracing is used
The BiDir engine is unchanged as its implementation was the reference.
The original problem, leading to the implementation in BiDir, was described in this forums post (with example images):
viewtopic.php?f=4&t=4219
The contrasting observation for Path+Light (with example images) was posted in this GitHub issue:
https://github.com/LuxCoreRender/LuxCore/issues/671
In the SDL, the syntax is as follows:
scene.materials.MaterialName.transparency.shadowoverride = 1
Additional explanation:
The mechanism of shadow color is a biased technique, and using it leads to different behavior between path- and light-rays unless some explicit decision is made.
In case these paths are very similar, this just leads to double brightness. (See the linked original problem)
In case the paths are very different, there may be some merit for artistic applications. (See the linked GitHub Issue)
BlendLuxCore now features an "override" setting that allows light-tracing rays when the shadow color is not black.
With this setting, the present behavior of Path+Light can be restored, and likewise be achieved with BiDir.
Re: [LuxCore + BlendLuxCore] [v2.11] Breaking Default Behavior - ShadowColor + Light Tracing
Thank you for your work. Maybe I will setup a test scene in the next days.
Maybe you remember the orange juice discussions a few years ago 😀
I don't specifically remember any discussions, but this scene was also on my mind as it had changed look since it was originally created. (It got brighter.)
However, during my test now, this new change had no impact on the look of the scene.
By the way, I reopened the Issue because I still noticed that there is one bug left:
GPU with OCL backend still leaks light and produces too bright results.
So probably it wouldn't fully work for you on GPU yet.
CUDA is working, which is why I missed this, doesn't show as obvious in all situations
e=1760390386 user_id=456]
[/quote]
I have a PC with two graphics cards, one AMD and one nvidia. So, I can compare CUDA with openCL directly.
Ah yes, I forgot, thought you were mac only...
BLC 2.10.1 | Glass Cube, no Volumes
I've tested different settings for a simple glass cube box filled with a yellow liquid.
First tests are material settings without volume.
I've encountered an issue with GPU rendering.
GeForce RTX 2080 Super renders only about 5% faster than Radeon RX 5700 XT (see LuxMark 3.1)
But here the combination CPU/Radeon renders much slower than CPU/GeForce.
If Light Tracing is enabled in combination with GPU RX 5700 XT the CPU AMD 5950X renders with the same speed as CPU only.
Compare AMD with aRX/AMD times for 0.5 HD renders in the lists below.
AMD: AMD Ryzen 9 5950X 16 cores, 32 threads
aRX: AMD Radeon RX 5700 XT
nRTX: NVIDIA RTX 2080 Super
CPU: Apple M1 16 GB
GPU: Apple M1 16 GB
Glass, sharp edges
Liquid, cube, sharp edges
Path-, Light Traycing Sobol
CPU, 128 samples, 2:38
AMD, 134 samples, 00:33
GPU/CPU, 128 Samples, 1:42
aRX/AMD, 134 Samples, 00:25
nRTX/AMD, 135 Samples, 00:15
aRX,nRTX/AMD, 152 Samples, 00:11
BiDir Metropolis
CPU, 128 Samples, 1:33
AMD, 131 Samples, d12, 00:23
CPU_BiDir MLT
CPU_BiDir MLT
CPU_Path, Light Tracing
CPU/GPU AMD, NVIDIA
CPU/GPU AMD, NVIDIA
CPU/GPU AMD
CPU/GPU AMD
CPU/GPU NVIDIA
CPU/GPU NVIDIA
Glass Cube, Volumes clear
Air, prio 0, clear
Glass, sharp edges, clear
Liquid, cube, sharp edges, clear
CPU, 128 Samples, 2:38
AMD, 131 Samples, 00:29
GPU/CPU, 128 Samples, 2:08
aRX/AMD, 130 Samples, 00:31
nRTX/AMD, 138 Samples, 00:16
aRX,nRTX/AMD, 128 Samples, 00:11
BiDir Metropolis
CPU, 128 Samples, 1:41
AMD, 128 Samples, d12, 00:25
CPU_BiDir, MLT
CPU_BiDir, MLT
CPU_PLT, Sobol
CPU_PLT, Sobol
CPU/aRX_PLT, Sobol
CPU/aRX_PLT, Sobol
CPU/nRTX_PLT, Sobol
CPU/nRTX_PLT, Sobol
CPU/aRX,nRTX_PLT, Sobol
Glass Cube, Volumes homo, Shadows 0
Air, prio 0, clear
Liquid, cube, sharp edges, homo
AMD, 134 Samples, 00:34
GPU/CPU, 128 Samples, 2:29
aRX/AMD, 131 Samples, 00:32
nRTX/AMD, 141 Samples, 00:17
aRX,nRTX/AMD, 144 Samples, 00:12
BiDir Metropolis
CPU, 128 Samples, 1:40
AMD, 129 Samples, d12, 00:24
CPU_PLT, Sobol
CPU_PLT, Sobol
CPU_BiDir, MLT
CPU_BiDir, MLT
CPU/aRX_PLT, Sobol
CPU/aRX_PLT, Sobol
CPU/nRTX_PLT, Sobol
CPU/nRTX_PLT, Sobol
Glass Cube, Volumes homo, Shadows 1
Air, prio 0, clear
Glass, sharp edges, clear, shadow 1
Liquid, cube, sharp edges, homo, shadow 1
CPU, 128 Samples, 2:19
AMD, 128 Samples, 00:32
aRX/AMD, 130 Samples, 00:33
aRX,nRTX/AMD, 141 Samples, 00:13
BiDir Metropolis
CPU, 128 Samples, 1:51
AMD, 129 Samples, d12, 00:26
CPU_PLT, Sobol
CPU_PLT, Sobol
CPU_BiDir, MLT
CPU_BiDir, MLT
CPU/aRX_PLT, Sobol
CPU/aRX_PLT, Sobol
CPU/nRTX_PLT, Sobol
CPU/nRTX_PLT, Sobol
Glass Cube, Volumes homo, Shadows 0.5
Air, prio 0, clear
Glass, sharp edges, clear, shadow 0.5
Liquid, cube, sharp edges, homo, shadow 0.5
CPU, 128 Samples,
AMD, 133 Samples, 00:30 (no light T: 00:14)
aRX/AMD, 131 Samples, 00:32 (no light T: 00:12)
nRTX/AMD, 135 Samples, 00:16
aRX,nRTX/AMD, 135 Samples, 00:11
BiDir Metropolis
CPU, 128 Samples,
AMD, 131 Samples, d12, 00:26
CPU_PLT, Sobol
CPU_PLT, Sobol
CPU_BiDir, MLT
CPU_BiDir, MLT
CPU/aRX_PLT, Sobol
CPU/aRX_PLT, Sobol
CPU/nRTX_PLT, Sobol
CPU/nRTX_PLT, Sobol
CPU/nRTX,aRX_PLT, Sobol
