Hey this is Dennis, one of the FLIP Fluids Addon developers.
We are actually testing our FLIP Fluids Addon with different Render-Engines. LuxCore performed very well in some tests! Thank you @all developers for your hard, and good work! LuxCore is amazing. A great render of a liquid drop is attached!
While testing i found out, that there is no attribute-input in the lux-shader-editor.
That one would make it possible to work with our flip-attributes (like colormixing as example).
As workaround i have tryed to use a cycles-shader, but that results in an error.
Maybe you have an idea about how to solve this?
If someone would like to check it, a .blend file is attached.
When you don´t have the FLIP Fluids Addon, you can download the free demo for testing/development.
Feel also free to contact us if you would like to talk about LuxCore+FLIP Fluid Addon.
Best regards,
Dennis
FLIP Fluids Addon & LuxCore (Attributes)
- Attachments
- luxcore-attributes-metallic.blend
- (856.5 KiB) Downloaded 2371 times
Re: FLIP Fluids Addon & LuxCore (Attributes)
Hi Dennis,
thanks for the good opinions!
I'm not familiar with this Cycles feature, but at first glance looks like it should not be much of a problem, requiring only addon changes and not the core library. Though I need to understand what your Flip-attributes actually contain.
Could you post that request directly as an Issue on GitHub in thsi repo: https://github.com/LuxCoreRender/BlendLuxCore
Always best if it is documented directly from the source.
Best,
Johannes
Best,
Johannes
Erledigt
