Artifacts when viewed without camera
Post by Racleborg »
Hi
When viewing without the camera I'm getting some strange triangular shaped artifacts (2 views attached: with and without the camera)
Thank you
Re: Artifacts when viewed without camera
Theses artifact are mostly visible in orthographic view not in perspective view.
True ??
Post by Racleborg »
True ??
Yes, that's correct.
Post by Racleborg »
.........so, is it normal to have artifacts in orthographic view?
Racleborg wrote: Mon Oct 15, 2018 6:53 am .........so, is it normal to have artifacts in orthographic view?
Only BYOB can solve it !
I think I might have seen this before.
Could you upload a scene that shows the problem?
B.Y.O.B. wrote: Mon Oct 15, 2018 9:30 am I think I might have seen this before.
I vaguely remember a problem related to having the camera far clipping plane to far (very faaaaaaar) :?:
Post by Racleborg »
Hi
I've simplified the scene (needed to be smaller to upload) but the issue is still there.
Thanks
artifacts.blend
(2.08 MiB) Downloaded 190 times
Racleborg wrote: Mon Oct 15, 2018 11:09 am Hi
Thanks
Properties > Scene > Units > Advanced LuxCore Settings >
Set Min. Epsilon higher (Default: 0.00001)
ie: set to: 0.0001
