OpenVDB instancing
bartek_zgo
OpenVDB instancing
Post by bartek_zgo »
Hi Guys,
I want to ask if there is some way to create more instances of the same VDB volume in an efficient way.
I have following volume definition:
scene.textures.VDB_density_texture.type = "densitygrid"
scene.textures.VDB_density_texture.nx = 295
scene.textures.VDB_density_texture.ny = 519
scene.textures.VDB_density_texture.nz = 159
scene.textures.VDB_density_texture.wrap = "black"
scene.textures.VDB_density_texture.openvdb.file = "cloud_10_variant_0000.vdb"
scene.textures.VDB_density_texture.openvdb.grid = "density"
scene.textures.VDB_density_texture.storage = "float"
scene.textures.VDB_density_texture.mapping.type = "globalmapping3d"
scene.textures.VDB_density_texture.mapping.transformation = 0.3389831 -0 0 -0 -0 0.1926782 -0 0 0 -0 0.6289309 -0 0.7030222 0.61531 0.7009416 1
scene.textures.VDB_density_texture_scale.type = "scale"
scene.textures.VDB_density_texture_scale.texture1 = "10000"
scene.textures.VDB_density_texture_scale.texture2 = "VDB_density_texture"
scene.volumes.VDB_volume.type = "heterogeneous"
scene.volumes.VDB_volume.absorption = "0 0 0"
scene.volumes.VDB_volume.scattering = "VDB_density_texture_scale"
scene.volumes.VDB_volume.asymmetry = "0 0 0"
scene.volumes.VDB_volume.multiscattering = 0
scene.volumes.VDB_volume.steps.size = 0.1
scene.volumes.VDB_volume.steps.maxcount = 1024
scene.volumes.VDB_volume.priority = 0
scene.volumes.VDB_volume.ior = "1"
scene.volumes.VDB_volume.id = 1,945,206
scene.volumes.VDB_volume.photongi.enable = 0
scene.materials.VDB_volume_material.type = "null"
scene.materials.VDB_volume_material.transparency.shadow = 0 0 0
scene.materials.VDB_volume_material.id = 5,251,573
scene.materials.VDB_volume_material.bumpsamplingdistance = 0.001
scene.materials.VDB_volume_material.volume.interior = "VDB_volume"
scene.materials.VDB_volume_material.visibility.indirect.diffuse.enable = 1
scene.materials.VDB_volume_material.visibility.indirect.glossy.enable = 1
scene.materials.VDB_volume_material.visibility.indirect.specular.enable = 1
scene.materials.VDB_volume_material.shadowcatcher.enable = 0
scene.materials.VDB_volume_material.shadowcatcher.onlyinfinitelights = 0
scene.materials.VDB_volume_material.photongi.enable = 1
scene.materials.VDB_volume_material.holdout.enable = 0
scene.objects.VDB_box.material = "VDB_volume_material"
scene.objects.VDB_box.ply = "mesh-00000.ply"
scene.objects.VDB_box.camerainvisible = 0
scene.objects.VDB_box.id = 1,326,487,202
scene.objects.VDB_box.appliedtransformation = 1 0 0 0 0 1 0 0 0 0 1 0 -0.4625384 -0.6505328 -1.751076 1
When I want to move or scale my volume I have to modify 2 transformations. One is
and the second is
The scene.objects.VDB_box.appliedtransformation is a box that will contain the VDB volume. If it is smaller it will crop the volume. If it is bigger it may have some side effects, but actually the size and location of this box does not change where the volume is located in the render.
The scene.textures.VDB_density_texture.mapping.transformation is the matrix where the volume is translated scaled etc.
So if I create new scene.object that will reference the same material I have no way to move or scale the volume, because the real move/scale transformation is applied to VDB_density_texture. So the only option I see hear is to create another material and another VDB_density_texture.
Is it correct approach?
If it is correct I'm afraid about performance. If I'm correct, luxcore will read vdb file twice. It will take a lot of time and memory.
And second question. I have seen that if I redefine VDB_density_texture during live session, because I want to move the volume, Luxcore reads VDB file again, so simple translation is time consuming task.
