twosided material
twosided material
Is there such material as twosided material in luxcore? For leaves or paper? Where one side shows some textures or properties that also can be seen while viewing from other side? Like looking at a paper from backside seeing whats on the other side?
Re: twosided material
For leaves jist use glossy translucent and check double side option.
lacilaci wrote: Sat Aug 11, 2018 1:55 pm Where one side shows some textures or properties that also can be seen while viewing from other side? Like looking at a paper from backside seeing whats on the other side?
I think there's no such material currently in LuxCore.
You will have to work with solidify, assigning a different material to the extruded face.
