Depth of Field issue
provisory
Post by provisory »
Hi all,
If I use a focus object for DoF, I always get a blurred image. It seems, that the focus isn't on that object.
It's the same with bidir and path and with all of the samplers.
Currently I use 2.1 alpha2.
I don't have a DGPU, so I only use CPU.
Re: Depth of Field issue
if you can upload the scene for investigation.
provisory
Post by provisory »
Here you go.
More info:
- with autofocus, everything is fine
- I use the version of BlendLuxCore without OpenCL support
dof_issue.blend
(475.32 KiB) Downloaded 546 times
Thanks for the report, I fixed the bug: https://github.com/LuxCoreRender/BlendL ... issues/196
provisory
Post by provisory »
Wow, it was fast! Thank you for your great work!
