Strange Effect Cube Volume
There is an object with many spheres. The spheres have material water. The spheres overlap with the cube. The cube has material glass. There are the volumes airvol prio 0, glassvol prio 15, watervol prio 5. Cube inside part of spheres is omitted because of priority setting. So far everything is well. What I don't understand is why the cubes is divided in subparts. I've tried with cube and subdivided cube with the same result. The scence attached is the version with the subdivided cube. What is wrong with the scene setup?
Strange Cube Volume Effect.zip
(1.38 MiB) Downloaded 668 times
Re: Strange Effect Cube Volume
Okay, my fault. :shock: There are several mistakes in the scene. I stripped it down to the cube. But the subparts seems to be nothing else than mirroring, resp. refraction effect. An illusion due to the chosen point of view. By the way blender default view.
Same cube, but rotated some degree around z-axis.
Strange Effect Cube Volume simplified
That's just total internal reflection.
I put a colored number on each side of the cube for illustration (the 1 is at the bottom).
By the way, you have the bubbles two times on top of each other (probably because you made the duplicates real, but forgot to delete the particle system).
B.Y.O.B. wrote: Sat Jul 28, 2018 12:00 pm That's just total internal reflection.
Very nice illustration. Thank you.
Yes, I forgot to delete particle system. Lot's of modifiers get deleted applying them but not so the particle system by pressing confirmation in the modifier tab.
