Hi all,
Is it possible to save the rendering from blender every some amount of time? I would need to have this feature because if I get a crash or windows makes something weird, I don't loose all of the hours' render.
To me, the best way would be that you set an interval of autosave and you get the output images, also with a log file of the samples reached, just in case I want to merge with a second render.
Best regards.
Interval saving
Re: Interval saving
It can be implemented, but it is not super trivial, which is why I didn't come to it yet.
However this would also require an easy to use program which can load the merged film and do the tonemapping.
I think it would be better to save the .flm, so you can just merge the films and let LuxCore do the math.Asticles wrote: Thu Jul 19, 2018 4:03 am also with a log file of the samples reached, just in case I want to merge with a second render.
Re: Interval saving
I know. But when doing this from Blender, I see these problems:
- color management will not be applied, so the image might look different from the final result in Blender
- compositing is obviously not applied
- If not only PNG/EXR, but also .flm should be saved, there's this issue: https://github.com/LuxCoreRender/LuxCore/issues/78
Re: Interval saving
A pity, because I would be a really useful feature.
Thanks
Thanks
Re: Interval saving
Is this option available in blender? I cannot find itDade wrote: Thu Jul 19, 2018 2:30 pm LuxCore already supports this feature via periodic saving properties![]()
Re: Interval saving
No, for the reasons I mentioned above.
You can export as LuxCore scene though and add the property: https://wiki.luxcorerender.org/LuxCore_ ... iodic_save
Or edit the export/config.py file in the addon and add the properties here: https://github.com/LuxCoreRender/BlendL ... fig.py#L32
Re: Interval saving
I should use standalone Luxcore for that, right?B.Y.O.B. wrote: Mon Dec 17, 2018 6:23 pmNo, for the reasons I mentioned above.
