Hello everyone,
This is a sample of the renders I have presented for my last project.
I'll be putting more pictures soon.
The originals are rendered at a higher resolution, so rendering times have been quite high.
Software: blender, luxcore, moi3d, lightwave, pixplant, gimp...
House in Spain
House in Spain
Re: House in Spain
And another.
Re: House in Spain
Very very nice project and render. Really like it. There is also this realistic touch always with luxcore. Beautifull.
If only you could gimp a more realistic grass into it (less green more random) we would say it is a photo.
Re: House in Spain
Solid work.
There are some minor things that could be improved, like the grass Sharlybg mentioned, or the repetitive stone wall tiling in the second image. But overall, good result.
Re: House in Spain
Thanks all for your kind words.
I tried to add variation to the grass but I got a lot of crashes when touching weights, so after some time I desist.
I've seen some people that puts all the grass from a photo, given it has the same perspective, but haven't tried.
The stone wall is what has to be, unfortunatelly, because is a fake stone wall and used de design of the manufacturer.
I will try on the next project to improve the grass, always difficult to me.
Also, at some time of the project, object space undo stopped working and gave instacrash on every undo. Mesh undo worked fine. Very annoying. Overall I'm happy with luxcore performance, although interior renders lasted too much hours. What I'm not so happy is with blender's crashes and poor viewport performance when all the scene is visible.
Best regards.
Best regards.
Re: House in Spain
I have done that in the past on professional projects, it works ok.Asticles wrote: Mon Jul 16, 2018 2:58 pm I've seen some people that puts all the grass from a photo, given it has the same perspective, but haven't tried.
E.g. here: https://carbonmade-media.accelerator.ne ... x1408.webp
https://byob.carbonmade.com/projects/3867633
You just need a material ID AOV pass to mask the grass area.
I am not sure if the Blender addon can cause this.Asticles wrote: Mon Jul 16, 2018 2:58 pm Also, at some time of the project, object space undo stopped working and gave instacrash on every undo. Mesh undo worked fine. Very annoying. Overall I'm happy with luxcore performance, although interior renders lasted too much hours. What I'm not so happy is with blender's crashes and poor viewport performance when all the scene is visible.
You could try to switch to Cycles, disable the BlendLuxCore addon and see if the crashes/poor performance still happen.
Re: House in Spain
Each time i see your nice archviz i always wonder wich part is CG wich one is real. Trees and plant are so well mad.have done that in the past on professional projects, it works ok.
Re: House in Spain
I hope I'm not derailing this thread, but here is the raw render (3ds max + Vray).Sharlybg wrote: Mon Jul 16, 2018 7:50 pm Each time i see your nice archviz i always wonder wich part is CG wich one is real.
Re: House in Spain
Yeah, this is really interesting. Which are your image grass sources?
Regards.
Regards.
Re: House in Spain
Mostly photos my former colleagues shot in the local city's parks.
