Pointer node broken in BlendLuxCore (plus fix!)
Martini
Post by Martini »
Hi :)
The Pointer node is missing the drop-down menu where you can select a Material, Volume, or Texture. This makes the node unusable.
I have opened an issue about it on GitHub here: https://github.com/LuxCoreRender/BlendL ... issues/770
And I have also submitted a PR to fix it :D See here: https://github.com/LuxCoreRender/BlendLuxCore/pull/769
Perhaps one of the devs could have a look? Thank you
Re: Pointer node broken in BlendLuxCore
Have tested your '"fix" & am confirming, 'Pointer' node is fully operational with it.
