Orthographic camera does not match 3D view
Burk
Post by Burk »
Windows 10, Blender 2.79b, Luxcore 2.0
For the orthographic camera the rendered image (F12) does not match the camera 3D view (Num 0) if the UnitScale is 0.1 (in property.scene.units)
With Cycles both images match.
see Example
LuxCore Orthographic Unit Scale.blend
(560.83 KiB) Downloaded 668 times
Is there a possibility to have a matching preview in the 3D view with LuxCore too?
neo2068
Re: Orthographic camera does not match 3D view
Post by neo2068 »
I am working on the issue. The first issue when unit scale isn't 1 should be fixed. There is a remaining issue with changing unit scale during view port rendering.
neo2068 wrote: Sun Jun 24, 2018 6:43 pm I am working on the issue. The first issue when unit scale isn't 1 should be fixed. There is a remaining issue with changing unit scale during view port rendering.
Thanks neo ;)
Burk
Post by Burk »
Thanks neo for the quick fix.
When and how will it be available?
Burk wrote: Tue Jun 26, 2018 10:08 am When and how will it be available?
When we release the next v2.1 alpha (no ETA yet).
