Hi, looking to get a nice old coin look. Please see below. I know it's bad, but that is why I'm here, to learn.
Pretty new to the material node stuff, but if someone came up with something, with a screenshot, I know I could plug it in so-to-speak.
I think I'm happy with the model. The detail is in the sculpt, no normal/displacement maps. Just always have problems with texture/lighting to get that really realistic look. For my pic, I just used metal, adjusted the roughness, then tried to get it looking best I could in PS.
medieval UK coin
Re: medieval UK coin
Hi modhop
Coincidentally, I'm working on a old pocket watch which requires a similar sort of 'old' look as your coin. It also has a similar amount of engraved detail (I'm impressed with your sculpting and confess that I've been cheating with a normal map!)
How about a bit of erratic roughness?
When I compare your render with reference images like this one, it is already close.
About the material: I would try to mix in some Matte to simulate the slight dirt layer, which is diffuse.
Since your coin is sculpted and has enough polygons, you can also try to play around with the Pointiness node, to place more dirt inside the crevices.
Maybe raise the roughness of the metal a bit more.
You should also consider the environment for the lighting.
Highly reflective materials like metal need something to reflect, so a black world background is usually a bad idea.
You can try to use an HDRI, we have some free ones linked in our wiki: https://wiki.luxcorerender.org/External ... 28HDRIs.29
And if you need an idea for a scene: You could scatter a few duplicates of the coin on a pile with Blender's physics (use a lowpoly version as collision cage).
Like this: https://cdn-images-1.medium.com/max/120 ... StVjT6.jpg
ok thx guys. Before I read your posts I played around with it a bit and came up with:
I guess this is what I'm going for:
http://www.londoncoins.co.uk/img.php?a= ... 29&f=o&s=l
one more, this time the complete stone look:
kind of like this:
https://3c1703fe8d.site.internapcdn.net ... ymoney.jpg
can't decide which direction I should go with.
kind of like this:
Modhop
I prefer your first version which I think has more detail - particularly to the left of the head and elbow of the rider.
BYOB
I'll definitely try your suggestions on projects such as this.
BYOB
Lol we appear to be posting at the same time.
You've got the detail back!
They all look good to me, but I still prefer the first
Edited: the second also looks a little concave. Could you add the worn look of the second to the first without loosing the fine detail?
Hmm interesting you prefer the 1st. I thought it looked like it was made from lead. I'll try to rough it up as you suggest.
...I prefer the first for the fine detail and prefer the second for the old material look.
(yes, maybe the first material does look a bit like lead)
Anyway, all your images look great to me in one way or another.
Cheers
Cheers
From what you've shown so far I like this one best: download/file.php?id=1285&mode=view
However it seems like the polygons from sculpting are still visible, you probably have to subdivide further and smooth it a bit (e.g. with dyntopo and smooth brush).
