bedroom interior render
edem fetor
Post by edem fetor »
hi everyone it's me again with a second rendering of a room with luxcore and the integrated library.
i hope you like it . image was rendered with GI cache on a i7 4770S in 20 mn 2k
just a question i saw that luxcore supports ocio and i would like to know where i can find a build of blendluxcore supporting ocio?
infact i want to try ACES.
Re: bedroom interior render
Really nice to see that you are getting familliar with the renderer
so fast. it contrast with so much people always complaining that
it is complexe compare to X Y Z E K :roll:
Well done !
JulianoLisboa
Post by JulianoLisboa »
Wonderful work, I loved the light. Keep it up.
Luximage
Post by Luximage »
Hello edem nice bedroom render.
As far as aces concerned it's not yet officially supported in blendluxcore but you can experiment with it by downloading aces colormanagement.
Here are some links to help you setup and use aces:
https://www.toodee.de/?page_id=1720
https://www.youtube.com/watch?v=B7FWNNDXBl0
https://www.youtube.com/watch?v=PkWT7HSEfJY
https://www.youtube.com/watch?v=8zb3XjNBgRE
There are different methods setting up aces see which works for you.
One tip i usually choose Rec.709 in view transform.
But With that You miss the space color input require by ACES for textures
and HDR images. There is also the need for blendluxcore addon to be set
to respect the appropriate color space as explained here in first post :
viewtopic.php?f=5&t=3446
Dez!
Post by Dez! »
great light! I especially like it on the bedding.
edem fetor
Thanks everyone for your kinds comments.
Sure I'm not going elsewhere after finding such a Gems.
Luxcore is really great ;)
Aces will make it perfect.
mnm
Post by mnm »
I like it. Do you mind share material setup and overall lightning strategy?
Regards
edem fetor
I just used the materials from the library that I then modified
for the walls it is a diffuse material
