Direct Light Sampling Cache (aka Light cache part I)
Post by Dade » Sun Jun 10, 2018 4:28 pm
Introduction
Direct Light Sampling Cache is intended to accelerate a specific type of scenes where:
1) many light sources are present;
2) light sources affect a limited part of the scene;
like a city with many lamps or a room with many small spot light sources.
Properties
The list of properties, with their default value, for DLSC in a .cfg are:
lightstrategy.type = DLS_CACHE
lightstrategy.entry.radius = 0.15
lightstrategy.entry.normalangle = 10.0
lightstrategy.entry.maxpasses = 1024
# 0.01 = 1%
lightstrategy.entry.convergencethreshold = 0.01
lightstrategy.entry.volumes.enable = 0
# 0.01 = 1%
lightstrategy.lightthreshold = 0.01
lightstrategy.targetcachehitratio = 0.995
lightstrategy.maxdepth = 4
lightstrategy.maxsamplescount = 10000000;
The only parameter you have to adapt for the scene is the "lightstrategy.entry.radius", it is the cache entry area of validity ad it is expressed in real word unit. So 0.15 means a 15 cm radius if you are rendering with 1m units.
All other parameters should be useful only to handle very specific cases and the default value should work fine for most scenes.
Original post
I'm working on the support for Direct Light Sampling Cache (aka Light cache part I or DLSC).
This result shows as little white spheres where the cache entries are placed:
Quite funny, so many little spheres :D
Supporting Users
Re: Direct Light Sampling Cache (aka Light cache part I)
Post by Sharlybg » Sun Jun 10, 2018 4:55 pm
So beautifull and wonderfull to have such power under your finger. The first time an opensource engine enter caching tech.
Post by B.Y.O.B. » Sun Jun 10, 2018 5:19 pm
I'm on the edge of my seat :)
Post by Dade » Mon Jun 11, 2018 10:21 am
DLSC is mostly intended to reduce noise when there are many light sources however, one of the results I will able to obtain, it is to disable direct light sampling for entries that are totally in shadow. This allows me to avoid to trace a shadow ray and speed up the rendering (i.e. less nose, more samples/sec).
This is a rendering with white little spheres on cache entries receiving light and red glowing little spheres for entries in pitch black (from direct light sampling point of view):
It isn't a result I originally planned but it is going to be quite useful. Even in a simple scene like the Cornell box, there is a significative amount of shadow rays saved.
patrickawalz
Supporting Users
Post by patrickawalz » Mon Jun 11, 2018 2:05 pm
another thought that is somewhat related (I think) tungsten and pbrt v3 both use a spatial light cache, albeit not exactly what you're doing. tungsten is using solid angle sampling iirc which is supposed to help calculate things faster. I believe pbrt v3 even has solid angle sampling of triangles in their code but doesn't employ it in their light cache. is this something you have looked into?
Post by Dade » Mon Jun 11, 2018 4:24 pm
I'm working in a somewhat different direction, my idea is to accelerate the rendering of many lights scenes so I build an octree of points where I compute the incoming radiance from all light sources and I use the value to build a Distribution (in PBRT speaking) to samples the light sources according their contribution.
So when I need to compute the direct light of any point in the scene I can use the Distribution of the nearest cached point to sample the most "important" light sources for the point. If the distribution is empty I can even skip direct light sampling all together. Indeed, I have to handle hard shadow borders careful but I have an idea for that problem.
In scenes with many light sources, this method should be vastly superior to the current generic light strategy.
This method is also unbiased.
This idea should be similar to "Adaptive Lights" used in VRay: https://www.chaosgroup.com/blog/underst ... ive-lights
patrickawalz
Supporting Users
Post by patrickawalz » Mon Jun 11, 2018 4:49 pm
interesting - the many light problem has been a hot topic the last couple of years - with a lot of people tackling it - it's always nice to pick your brain and get the reasons behind your decisions and directions you are taking
Dez!
Post by Dez! » Thu Jun 14, 2018 3:24 pm
What will it be? Even faster rendering?
ElementaryOS Loki | Dell Inspiron 7000 | Wacom
https://freelance.ru/dez1gner
Supporting Users
Post by Sharlybg » Thu Jun 14, 2018 4:21 pm
Fast rendering and super efficient sampling in scene with many light source.
Dez!
Post by Dez! » Fri Jun 15, 2018 7:23 am
Ouuu!!!
Photorealism will remain the same?
