Quick Interior made with Luxcore online library rendered with GI cache enable on GTX 1080ti :
https://cgtrader.com/draviastudio . Such a pleasure to work with Gi cache and caustic cache.
F.A.B interior Renders
Re: F.A.B interior Renders
Yes, libraries can speed things up a lot.
Too bad my LOL doesn't work, there's so much beautiful stuff there
Are you on blendluxcore lastest build.
And did you press the update TOC button ?
Old 2.5 dont work now because addon change.
I use Lux 2.6 and Blend 2.93.6.
Yes, LOL does not work in this bundle.
This doesn't make sense. Wich part isn't working.
Can you describ the error you get.
Are files not loading or what happen when you
click on the asset bar. you can also show a video
capture of the issue. It work here on my side :
Nice render, amazing job, I do not know if it is just me but the scene is a little bit like modern space movies, I mean it is like you use much of color instead of actual textures with random dirt on it, somehow it is perfect, and that makes it a little bit unrealistic.
it is just my opinion and may not be the correct one.
.I mean it is like you use much of color instead of actual textures with random dirt
very good point guy. Will try to use abit more irregularity especially on cloth shader
