"FATAL ERROR RUNNING CMAKE" at Windows
I'm attempting to build according to the guide of https://github.com/LuxCoreRender/WindowsCompile with VS 2019
When I build LuxCore on Windows like below...
After running cmake-build-x64.bat... "FATAL ERROR RUNNING CMAKE" occurs.
When I opened the CMakeError.log file... it say they can't find "CheckInclusiveFile.c".
How can I solve this problem?
** Visual Studio 2019 Developer Command Prompt v16.11.3
** Copyright (c) 2021 Microsoft Corporation
[vcvarsall.bat] Environment initialized for: 'x86'
C:\git\luxcorerender\WindowsCompile>cmake-build-x64.bat
Detected Visual Studio (version 16.0)
Finding if CMake is installed...
CMake found at "C:\Program Files (x86)\Microsoft Visual Studio\2019\Professional\Common7\IDE\CommonExtensions\Microsoft\CMake\CMake\bin\cmake.exe "
--2021-09-23 21:31:15-- https://github.com/LuxCoreRender/Window ... _v2.6_3.7z
Resolving github.com (github.com)... 15.164.81.167
Connecting to github.com (github.com)|15.164.81.167|:443... connected.
HTTP request sent, awaiting response... 302 Found
Location: https://github-releases.githubuserconte ... tet-stream [following]
--2021-09-23 21:31:17-- https://github-releases.githubuserconte ... tet-stream
Resolving github-releases.githubusercontent.com (github-releases.githubusercontent.com)... 185.199.108.154, 185.199.110.154, 185.199.109.154, ...
Connecting to github-releases.githubusercontent.com (github-releases.githubusercontent.com)|185.199.108.154|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 105678346 (101M) [application/octet-stream]
Saving to: 'WindowsCompileDeps_v2.6_3.7z'
WindowsCompileDeps_v2.6_3.7z 100%[=================================================>] 100.78M 862KB/s in 99s
-- Using Win32 for window creation
-- Using WGL for context creation
-- Configuring incomplete, errors occurred!
See also "C:/git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/CMakeFiles/CMakeOutput.log".
See also "C:/git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/CMakeFiles/CMakeError.log".
--- FATAL ERROR RUNNING CMAKE ---
C:\git\luxcorerender\WindowsCompile\Build_CMake\LuxCore\CMakeFiles\CMakeTmp\CheckIncludeFile.c(1,10): fatal error C1083: Can't open the include file.. 'pthread.h': No such file or directory [C:\git\luxcorerender\WindowsCompile\Build_CMake\LuxCore\CMakeFiles\CMakeTmp\cmTC_45888.vcxproj]
Re: "FATAL ERROR RUNNING CMAKE" at Windows
You are using the "x86 Native Tools" command prompt of Visual Studio, you need the "x64 Native Tools" to build LuxCore.
Hi acasta69
Thank you for answering despite your busy schedule.
I ran cmake-build-x64.bat again with x64 Native tools.
Unfortunately, the same error comes out. Do you have any additional suggestions?
[vcvarsall.bat] Environment initialized for: 'x64'
... skip
-- Lux build environment variables found
-- LUX_WINDOWS_BUILD_ROOT = E:\Git\luxcorerender\WindowsCompile
-- INCLUDE_DIR = E:\Git\luxcorerender\WindowsCompileDeps\include
-- LIB_DIR = E:\Git\luxcorerender\WindowsCompileDeps\x64\Release\lib
-- Looking for pthread.h
-- Looking for pthread.h - not found
See also "E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/CMakeFiles/CMakeOutput.log".
See also "E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/CMakeFiles/CMakeError.log".
[CMakeError.log]
cl /c /Zi /W3 /WX- /diagnostics:column /Od /Ob0 /D WIN32 /D _WINDOWS /D "CMAKE_INTDIR=\"Debug\"" /D _MBCS /Gm- /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /Zc:inline /Fo"cmTC_95d01.dir\Debug\\" /Fd"cmTC_95d01.dir\Debug\vc142.pdb" /external:W3 /Gd /TC /errorReport:queue E:\Git\luxcorerender\WindowsCompile\Build_CMake\LuxCore\CMakeFiles\CMakeTmp\CheckIncludeFile.c
E:\Git\luxcorerender\WindowsCompile\Build_CMake\LuxCore\CMakeFiles\CMakeTmp\CheckIncludeFile.c(1,10): fatal error C1083: I can't open the included file.. 'pthread.h': No such file or directory [E:\Git\luxcorerender\WindowsCompile\Build_CMake\LuxCore\CMakeFiles\CMakeTmp\cmTC_95d01.vcxproj]
... skip
[CMakeError.log]
Hi kivahan,
sorry that the problem was not solved: I noticed the "x86" prompt and hoped that using the "x64" would solve config problems.
However, the "pthread.h not found" is not a problem on Windows, I have the same message here and the build succeeds:
Can you please post the full "cmake-build-x64.bat" output, without skipping parts? There could be some helpful message there.
Also please use the "code" tags to enclose the output, it makes it more readable (you can do that using the "</>" button above the typing pane).
-- Found Threads: TRUE
Hi acasta69
Thank you for helping me despite your busy schedule.
The entire log was extracted. I hope we can find the cause. [CMakeError.log] is the same as the previous post.
Thank you in advance.
C:\Program Files (x86)\Microsoft Visual Studio\2019\Professional>e:
E:\>cd E:\Git\luxcorerender\WindowsCompile\
E:\Git\luxcorerender\WindowsCompile>dir
E 드라이브의 볼륨에는 이름이 없습니다.
볼륨 일련 번호: 8E4F-CABA
E:\Git\luxcorerender\WindowsCompile 디렉터리
2021-09-24 오후 12:11 <DIR> .
2021-09-24 오후 12:11 <DIR> ..
2021-09-24 오후 12:06 <DIR> .github
2021-09-23 오후 08:48 93 .gitignore
2021-09-23 오후 08:48 27,168 build-deps-x64.bat
2021-09-24 오후 12:06 <DIR> Build_CMake
2021-09-23 오후 08:48 9,010 cmake-build-x64.bat
2021-09-23 오후 08:48 947 collect-compiled-binaries.bat
2021-09-23 오후 08:48 1,362 create-luxmark.bat
2021-09-23 오후 08:48 2,432 create-sdk.bat
2021-09-23 오후 08:48 1,804 create-standalone.bat
2021-09-23 오후 08:48 16,321 getdeps.bat
2021-09-24 오후 12:11 <DIR> luxcorerender
2021-09-23 오후 08:48 3,336 README.txt
2021-09-24 오후 12:06 <DIR> support
2021-07-16 오전 04:44 105,678,346 WindowsCompileDeps_v2.6_3.7z
10개 파일 105,740,819 바이트
6개 디렉터리 770,945,282,048 바이트 남음
E:\Git\luxcorerender\WindowsCompile>cmake-build-x64.bat
We are using CMake version: 3
LIB_DIR: E:\Git\luxcorerender\WindowsCompileDeps\x64\Release\lib
CMAKE_OPTS=-G "Visual Studio 16 2019" -A x64 -T v142,host=x64 -D CMAKE_INCLUDE_PATH="E:\Git\luxcorerender\WindowsCompileDeps\include" -D CMAKE_LIBRARY_PATH="E:\Git\luxcorerender\WindowsCompileDeps\x64\Release\lib" -D PYTHON_LIBRARY="E:\Git\luxcorerender\WindowsCompileDeps\x64\Release\lib" -D PYTHON_V="39" -D PYTHON_INCLUDE_DIR="E:\Git\luxcorerender\WindowsCompileDeps\include\Python39" -D CMAKE_BUILD_TYPE=Release -DWIN_BUILD_DEMOS=1
하위 디렉터리 또는 파일 Build_CMake이(가) 이미 있습니다.
하위 디렉터리 또는 파일 E:\Git\luxcorerender\WindowsCompile\Build_CMake\LuxCore이(가) 이미 있습니다.
-- CMake version 3.20.21032501-MSVC_2 detected
-- Selecting Windows SDK version 10.0.19041.0 to target Windows 10.0.17134.
-- The C compiler identification is MSVC 19.29.30133.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Professional/VC/Tools/MSVC/14.29.30133/bin/Hostx64/x64/cl.exe - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- The CXX compiler identification is MSVC 19.29.30133.0
CMake Warning (dev) at C:/Program Files (x86)/Microsoft Visual Studio/2019/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/share/cmake-3.20/Modules/CMakeDetermineCXXCompiler.cmake:162 (if):
Policy CMP0054 is not set: Only interpret if() arguments as variables or
keywords when unquoted. Run "cmake --help-policy CMP0054" for policy
details. Use the cmake_policy command to set the policy and suppress this
warning.
Quoted variables like "MSVC" will no longer be dereferenced when the policy
is set to NEW. Since the policy is not set the OLD behavior will be used.
Call Stack (most recent call first):
CMakeLists.txt:43 (enable_language)
This warning is for project developers. Use -Wno-dev to suppress it.
CMake Warning (dev) at C:/Program Files (x86)/Microsoft Visual Studio/2019/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/share/cmake-3.20/Modules/CMakeDetermineCXXCompiler.cmake:183 (elseif):
warning.
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Professional/VC/Tools/MSVC/14.29.30133/bin/Hostx64/x64/cl.exe - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Multi-config generator detected
-- MSVC
-- MSVC Version: 1929
-- Available custom configurations in cmake/SpecializedConfig:
-- Config_Dade
-- Config_Linux-Static
-- Config_OSX
-- Config_Windows
-- Using custom build config: cmake\SpecializedConfig\Config_Windows.cmake
-- Using Windows Configuration settings
-- Building for target x86
-- Found OpenImageIO: E:/Git/luxcorerender/WindowsCompileDeps/x64/Release/lib/OpenImageIO.lib
CMake Warning (dev) at C:/Program Files (x86)/Microsoft Visual Studio/2019/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/share/cmake-3.20/Modules/FindPackageHandleStandardArgs.cmake:438 (message):
The package name passed to `find_package_handle_standard_args` (OPENEXR)
does not match the name of the calling package (OpenEXR). This can lead to
problems in calling code that expects `find_package` result variables
(e.g., `_FOUND`) to follow a certain pattern.
cmake/Packages/FindOpenEXR.cmake:120 (FIND_PACKAGE_HANDLE_STANDARD_ARGS)
cmake/Dependencies.cmake:33 (find_package)
CMakeLists.txt:103 (include)
-- Found OPENEXR: E:/Git/luxcorerender/WindowsCompileDeps/x64/Release/lib/Iex.lib;E:/Git/luxcorerender/WindowsCompileDeps/x64/Release/lib/IlmImf.lib;E:/Git/luxcorerender/WindowsCompileDeps/x64/Release/lib/Half.lib;E:/Git/luxcorerender/WindowsCompileDeps/x64/Release/lib/Imath.lib;E:/Git/luxcorerender/WindowsCompileDeps/x64/Release/lib/IlmThread.lib
-- Found TIFF: E:/Git/luxcorerender/WindowsCompileDeps/x64/Release/lib/libtiff.lib (found version "4.0.9")
-- Found JPEG: E:/Git/luxcorerender/WindowsCompileDeps/x64/Release/lib/jpeg.lib (found version "90")
-- Found ZLIB: E:/Git/luxcorerender/WindowsCompileDeps/x64/Release/lib/zlib1.lib (found version "1.2.11")
-- Found PNG: E:/Git/luxcorerender/WindowsCompileDeps/x64/Release/lib/libpng.lib (found version "1.6.37")
-- Found PythonLibs: E:/Git/luxcorerender/WindowsCompileDeps/x64/Release/lib (found suitable version "3.9.5", minimum required is "3.4")
-- Found Boost: E:/Git/luxcorerender/WindowsCompileDeps/include/Boost (found suitable version "1.72.0", minimum required is "1.56.0") found components: thread program_options filesystem serialization iostreams regex system python39 chrono serialization numpy39 date_time missing components: atomic
-- Found OpenGL: opengl32
-- Found OpenMP_C: -openmp (found version "2.0")
-- Found OpenMP_CXX: -openmp (found version "2.0")
-- Found OpenMP: TRUE (found version "2.0")
-- OpenMP found - compiling with
CMake Error at C:/Program Files (x86)/Microsoft Visual Studio/2019/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/share/cmake-3.20/Modules/FindBISON.cmake:113 (message):
Command "E:\Git\luxcorerender\WindowsCompile/support/bin/win_bison.exe
--version" failed with output:
cmake/Dependencies.cmake:156 (find_package)
-- Found BISON: E:\Git\luxcorerender\WindowsCompile/support/bin/win_bison.exe
-- Found FLEX: E:\Git\luxcorerender\WindowsCompile/support/bin/win_flex.exe (found version "2.6.4")
-- OpenCL support: enabled
-- CUDA support: enabled
-- Intel OIDN support: enabled
-- Could NOT find Doxygen (missing: DOXYGEN_EXECUTABLE)
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/luxrays_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/luxrays_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/core/color/color_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/color_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/core/color/color_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/color_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/core/bvh/bvhbuild_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/bvhbuild_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/accelerators/bvh.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/bvh_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/accelerators/mbvh.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/mbvh_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/accelerators/optixaccel.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/optixaccel_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/accelerators/optixemptyaccel.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/optixemptyaccel_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/core/exttrianglemesh_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/exttrianglemesh_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/core/exttrianglemesh_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/exttrianglemesh_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/core/randomgen_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/randomgen_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/core/randomgen_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/randomgen_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/core/trianglemesh_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/trianglemesh_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/core/geometry/matrix4x4_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/matrix4x4_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/core/geometry/matrix4x4_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/matrix4x4_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/core/geometry/transform_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/transform_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/core/geometry/transform_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/transform_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/core/geometry/frame_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/frame_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/core/geometry/frame_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/frame_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/core/epsilon_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/epsilon_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/core/epsilon_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/epsilon_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/core/geometry/ray_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/ray_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/core/geometry/ray_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/ray_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/core/geometry/point_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/point_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/core/geometry/vector_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/vector_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/core/geometry/vector_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/vector_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/core/geometry/normal_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/normal_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/core/geometry/quaternion_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/quaternion_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/core/geometry/quaternion_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/quaternion_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/core/geometry/bbox_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/bbox_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/core/geometry/bbox_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/bbox_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/core/geometry/motionsystem_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/motionsystem_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/core/geometry/motionsystem_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/motionsystem_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/core/geometry/triangle_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/triangle_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/core/geometry/triangle_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/triangle_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/core/geometry/uv_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/uv_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/core/utils_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/utils_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/devices/cudadevice_math.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/cudadevice_math_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/devices/cudadevice_oclemul_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/cudadevice_oclemul_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/devices/cudadevice_oclemul_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/cudadevice_oclemul_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/devices/ocldevice_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/ocldevice_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/utils/atomic_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/atomic_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/luxrays/utils/mc_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/luxrays-kernels/mc_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/cameras/camera_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/camera_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/cameras/camera_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/camera_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/engines/caches/photongi/pgic_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/pgic_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/engines/caches/photongi/pgic_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/pgic_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/engines/pathoclbase/kernels/pathoclbase_datatypes.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/pathoclbase_datatypes_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/engines/pathoclbase/kernels/pathoclbase_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/pathoclbase_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/engines/pathoclbase/kernels/pathoclbase_kernels_micro.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/pathoclbase_kernels_micro_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/engines/pathtracer_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/pathtracer_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/film/film_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/film_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/film/film_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/film_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/film/film_mergesamplebuffer_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/film_mergesamplebuffer_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/film/denoiser/filmdenoiser_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/filmdenoiser_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/film/sampleresult_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/sampleresult_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/film/imagepipeline/plugins/plugin_backgroundimg_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/plugin_backgroundimg_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/film/imagepipeline/plugins/plugin_bloom_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/plugin_bloom_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/film/imagepipeline/plugins/plugin_cameraresponse_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/plugin_cameraresponse_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/film/imagepipeline/plugins/plugin_coloraberration_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/plugin_coloraberration_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/film/imagepipeline/plugins/plugin_gammacorrection_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/plugin_gammacorrection_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/film/imagepipeline/plugins/plugin_gaussianblur3x3_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/plugin_gaussianblur3x3_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/film/imagepipeline/plugins/plugin_objectidmask_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/plugin_objectidmask_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/film/imagepipeline/plugins/plugin_optixdenoiser_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/plugin_optixdenoiser_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/film/imagepipeline/plugins/plugin_premultiplyalpha_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/plugin_premultiplyalpha_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/film/imagepipeline/plugins/plugin_vignetting_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/plugin_vignetting_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/film/imagepipeline/plugins/plugin_whitebalance_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/plugin_whitebalance_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/film/imagepipeline/plugins/tonemaps/tonemap_reduce_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/tonemap_reduce_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/film/imagepipeline/plugins/tonemaps/tonemap_autolinear_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/tonemap_autolinear_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/film/imagepipeline/plugins/tonemaps/tonemap_linear_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/tonemap_linear_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/film/imagepipeline/plugins/tonemaps/tonemap_luxlinear_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/tonemap_luxlinear_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/film/imagepipeline/plugins/tonemaps/tonemap_reinhard02_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/tonemap_reinhard02_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/film/sampleresult_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/sampleresult_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/film/filters/filter_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/filter_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/film/filters/filter_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/filter_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/imagemap/imagemap_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/imagemap_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/imagemap/imagemap_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/imagemap_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/lights/light_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/light_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/lights/light_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/light_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/lights/strategies/dlsc_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/dlsc_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/lights/strategies/dlsc_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/dlsc_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/lights/strategies/lightstrategy_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/lightstrategy_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/lights/visibility/elvc_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/elvc_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/lights/visibility/elvc_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/elvc_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/samplers/sampler_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/sampler_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/samplers/sampler_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/sampler_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/samplers/sampler_random_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/sampler_random_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/samplers/sampler_sobol_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/sampler_sobol_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/samplers/sampler_metropolis_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/sampler_metropolis_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/samplers/sampler_tilepath_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/sampler_tilepath_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/bsdf/bsdf_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/bsdf_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/bsdf/bsdf_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/bsdf_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/bsdf/bsdfutils_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/bsdfutils_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/bsdf/hitpoint_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/hitpoint_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/bsdf/hitpoint_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/hitpoint_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/materials/material_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/material_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/materials/materialdefs_funcs_generic.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/materialdefs_funcs_generic_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/materials/materialdefs_funcs_default.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/materialdefs_funcs_default_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/materials/materialdefs_funcs_archglass.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/materialdefs_funcs_archglass_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/materials/materialdefs_funcs_carpaint.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/materialdefs_funcs_carpaint_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/materials/materialdefs_funcs_clearvol.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/materialdefs_funcs_clearvol_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/materials/materialdefs_funcs_cloth.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/materialdefs_funcs_cloth_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/materials/materialdefs_funcs_glass.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/materialdefs_funcs_glass_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/materials/materialdefs_funcs_glossy2.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/materialdefs_funcs_glossy2_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/materials/materialdefs_funcs_glossycoating.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/materialdefs_funcs_glossycoating_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/materials/materialdefs_funcs_glossytranslucent.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/materialdefs_funcs_glossytranslucent_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/materials/materialdefs_funcs_heterogeneousvol.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/materialdefs_funcs_heterogeneousvol_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/materials/materialdefs_funcs_homogeneousvol.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/materialdefs_funcs_homogeneousvol_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/materials/materialdefs_funcs_matte.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/materialdefs_funcs_matte_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/materials/materialdefs_funcs_matte_translucent.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/materialdefs_funcs_matte_translucent_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/materials/materialdefs_funcs_metal2.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/materialdefs_funcs_metal2_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/materials/materialdefs_funcs_mirror.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/materialdefs_funcs_mirror_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/materials/materialdefs_funcs_mix.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/materialdefs_funcs_mix_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/materials/materialdefs_funcs_null.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/materialdefs_funcs_null_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/materials/materialdefs_funcs_roughglass.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/materialdefs_funcs_roughglass_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/materials/materialdefs_funcs_roughmatte_translucent.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/materialdefs_funcs_roughmatte_translucent_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/materials/materialdefs_funcs_thinfilmcoating.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/materialdefs_funcs_thinfilmcoating_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/materials/materialdefs_funcs_velvet.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/materialdefs_funcs_velvet_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/materials/materialdefs_funcs_disney.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/materialdefs_funcs_disney_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/materials/materialdefs_funcs_twosided.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/materialdefs_funcs_twosided_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/materials/material_funcs_evalops.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/material_funcs_evalops_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/materials/material_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/material_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/scene/scene_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/scene_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/scene/scene_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/scene_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/scene/sceneobject_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/sceneobject_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/textures/hitpoint/texture_hitpoint_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/texture_hitpoint_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/textures/mapping/mapping_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/mapping_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/textures/mapping/mapping_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/mapping_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/textures/math/texture_abs_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/texture_abs_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/textures/math/texture_clamp_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/texture_clamp_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/textures/math/texture_random_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/texture_random_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/textures/texture_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/texture_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/textures/texture_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/texture_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/textures/texture_funcs_evalops.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/texture_funcs_evalops_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/textures/texture_bilerp_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/texture_bilerp_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/textures/texture_blackbody_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/texture_blackbody_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/textures/texture_blender_noise_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/texture_blender_noise_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/textures/texture_blender_noise_funcs2.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/texture_blender_noise_funcs2_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/textures/texture_blender_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/texture_blender_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/textures/texture_bombing_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/texture_bombing_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/textures/texture_brick_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/texture_brick_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/textures/texture_bump_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/texture_bump_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/textures/texture_colordepth_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/texture_colordepth_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/textures/texture_densitygrid_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/texture_densitygrid_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/textures/texture_distort_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/texture_distort_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/textures/texture_hsv_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/texture_hsv_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/textures/texture_irregulardata_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/texture_irregulardata_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/textures/texture_noise_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/texture_noise_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/textures/texture_imagemap_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/texture_imagemap_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/textures/texture_others_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/texture_others_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/textures/texture_triplanar_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/texture_triplanar_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/textures/fresnel/texture_fresnelcolor_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/texture_fresnelcolor_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/textures/fresnel/texture_fresnelconst_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/texture_fresnelconst_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/utils/evalstack_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/evalstack_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/utils/mortoncurve_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/mortoncurve_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/utils/pathdepthinfo_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/pathdepthinfo_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/utils/pathdepthinfo_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/pathdepthinfo_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/utils/pathvolumeinfo_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/pathvolumeinfo_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/utils/pathvolumeinfo_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/pathvolumeinfo_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/utils/pathinfo_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/pathinfo_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/utils/pathinfo_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/pathinfo_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/utils/varianceclamping_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/varianceclamping_funcs_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/volumes/volume_types.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/volume_types_kernel.cpp
-- Preprocessing OpenCL kernel: E:/Git/luxcorerender/LuxCore/include/slg/volumes/volume_funcs.cl => E:/Git/luxcorerender/WindowsCompile/Build_CMake/LuxCore/generated/slg-kernels/volume_funcs_kernel.cpp
CMake Warning at src/pyluxcoretools/CMakeLists.txt:74 (message):
pyside-uic not available - using pre-generated files from the source tree
CMake Deprecation Warning at samples/luxcoreui/deps/glfw-3.1.1/CMakeLists.txt:3 (cmake_minimum_required):
Compatibility with CMake < 2.8.12 will be removed from a future version of
CMake.
Update the VERSION argument <min> value or use a ...<max> suffix to tell
CMake that the project does not need compatibility with older versions.
CMake Deprecation Warning at samples/luxcoreui/deps/glfw-3.1.1/CMakeLists.txt:8 (cmake_policy):
The OLD behavior for policy CMP0042 will be removed from a future version
of CMake.
The cmake-policies(7) manual explains that the OLD behaviors of all
policies are deprecated and that a policy should be set to OLD only under
specific short-term circumstances. Projects should be ported to the NEW
behavior and not rely on setting a policy to OLD.
Hi, the problem seems to be that Bison version is not recognized in your system:
Why this happens, might be a bit difficult to understand, since it's handled by a CMake internal script.
Can you please post the output of this command (same command prompt where you normally run "cmake-build-x64.bat"):
As a workaround, at least for the moment, you should be able to build LuxCore by editing "cmake-build-x64.bat".
Line 218 should look like this:
Try to add "-D BISON_NOT_AVAILABLE=1" to that line, as shown below:
When this happens, CMake actually does not generate the build, even if the process seems to be continuing.kivahan wrote: Thu Sep 30, 2021 6:12 amCode: Select all
... CMake Error at C:/Program Files (x86)/Microsoft Visual Studio/2019/Professional/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/share/cmake-3.20/Modules/FindBISON.cmake:113 (message): Command "E:\Git\luxcorerender\WindowsCompile/support/bin/win_bison.exe --version" failed with output: Call Stack (most recent call first): cmake/Dependencies.cmake:156 (find_package) CMakeLists.txt:103 (include) -- Found BISON: E:\Git\luxcorerender\WindowsCompile/support/bin/win_bison.exe ...
support\bin\win_bison.exe --version
"%CMAKE%" %CMAKE_OPTS% -D LUXRAYS_CUSTOM_CONFIG=cmake\SpecializedConfig\Config_Windows.cmake %LUXCORE_ROOT%
"%CMAKE%" %CMAKE_OPTS% -D LUXRAYS_CUSTOM_CONFIG=cmake\SpecializedConfig\Config_Windows.cmake -D BISON_NOT_AVAILABLE=1 %LUXCORE_ROOT%
Hi acasta69,
Modifying .bat didn't help, and there was no win_bison.exe file in the bin directory below, and there was a "win_flex.exe" file instead.
So I forcibly renamed this file win_bison.exe.
After doing that, I tried to build it again.
but.. fail again could you check bleow?
"slg-core.dir\Release\/textures/math/power.cpp.obj"
"slg-core.dir\Release\/textures/math/random.cpp.obj"
slg-core.vcxproj -> C:\git\luxcorerender\WindowsCompile\Build_CMake\LuxCore\lib\Release\slg-core.lib
FinalizeBuildStatus:
"slg-core.dir\Release\slg-core.tlog\unsuccessfulbuild" deleting the file..
"slg-core.dir\Release\slg-core.tlog\slg-core.lastbuildstate" connecting to it..
3>"C:\git\luxcorerender\WindowsCompile\Build_CMake\LuxCore\src\slg\slg-core.vcxproj" built the project (default target)
1>"C:\git\luxcorerender\WindowsCompile\Build_CMake\LuxCore\LuxRays.sln" The project has been built (default target). - Failed
Failed to build.
"C:\git\luxcorerender\WindowsCompile\Build_CMake\LuxCore\LuxRays.sln"(기본 대상)(1)->
"C:\git\luxcorerender\WindowsCompile\Build_CMake\LuxCore\src\luxcore\luxcore.vcxproj"(기본 대상)(8)->
(CustomBuild 대상) ->
C:\Program Files (x86)\Microsoft Visual Studio\2019\Professional\MSBuild\Microsoft\VC\v160\Microsoft.CppCommon.targets(241,5): error MSB8066: 'C:\git\luxcorerender\W
indowsCompile\Build_CMake\LuxCore\CMakeFiles\32170ef053fb14f11ce95a1362c1667e\luxparse.cpp.rule;C:\git\luxcorerender\WindowsCompile\Build_CMake\LuxCore\CMakeFiles\3217
0ef053fb14f11ce95a1362c1667e\luxlex.cpp.rule' Custom build has ended (code 1). [C:\git\luxcorerender\WindowsCompile\Build_CMake\LuxCore\src\luxcore\luxcore.vcxproj]
0 warning.
1 error.
Time elapsed: 00:05:40.72
There should be a win_bison.exe there, see https://github.com/LuxCoreRender/Window ... upport/bin, and renaming win_flex is not ok, they are two different programs.kivahan wrote: Sat Oct 09, 2021 1:54 am Modifying .bat didn't help, and there was no win_bison.exe file in the bin directory below, and there was a "win_flex.exe" file instead.
I think your local WindowsCompile repository has got corrupted, please try to clone it again.
Hi acasta69,
There was the Trojan/Win32.Wacatac virus in win_bison.exe. My computer's V3 Vacine detected this virus and deleted it.
After deleting the existing git and receiving the git clone again, win_bison went into the past commit, not the latest commit,
and downloaded win_bison.exe, so the virus was not detected.
But I tried to build it again, but it was a failure.
Is the issue below also a win_bison.exe problem? Should we have the latest win_bison.exe?
3>"C:\git\luxcorerender\WindowsCompile\Build_CMake\LuxCore\src\slg\slg-core.vcxproj" Failed to build.
1>"C:\git\luxcorerender\WindowsCompile\Build_CMake\LuxCore\LuxRays.sln" Failed to build. - fail
Failed to build.
"C:\git\luxcorerender\WindowsCompile\Build_CMake\LuxCore\LuxRays.sln"(default)(1)->
"C:\git\luxcorerender\WindowsCompile\Build_CMake\LuxCore\src\luxcore\luxcore.vcxproj"(default)(8)->
(CustomBuild ) ->
C:\Program Files (x86)\Microsoft Visual Studio\2019\Professional\MSBuild\Microsoft\VC\v160\Microsoft.CppCommon.targets(241,5): error MSB8066: 'C:\git\luxcorerender\WindowsCompile\Build_CMake\LuxCore\CMakeFiles\32170ef053fb14f11
ce95a1362c1667e\luxparse.cpp.rule;C:\git\luxcorerender\WindowsCompile\Build_CMake\LuxCore\CMakeFiles\32170ef053fb14f11ce95a1362c1667e\luxlex.cpp.rule' The custom build for this has ended (code 1).. [C:\git\luxcorerender\WindowsCompile\Build_CMake
warning 0
fail 1
time: 00:05:44.61
I cannot understand what is going on just by seeing the last lines, they give no detail about what caused the error. Please post the whole output.
If you are using the latest commit of our repository, it should work just fine.
The win_bison version in our git repo is ok, you don't need the latest version. What do you mean with "past commit"?
