Lamps
Asticles
Lamps
Post by Asticles »
I've made a little test with a couple of lamps and dof.
I attach the scene but materials keep disconnected when I reopen it.
lux2.blend
(908.41 KiB) Downloaded 25403 times
Regards
neo2068
Re: Lamps
Post by neo2068 »
Great image. The disconnecting of the materials is a known bug in blender which has been reported by B.Y.O.B. th the blender devs. The fix is now in trunk and will be part of a 2.79a release.
david57
Re: Lamps
Post by david57 »
I tried this scene with the settings OpenCl : Path : Metropolis and has been crashing.
Sobol works fine.
Re: Lamps
Check if your graphics card runs out of memory.
Metropolis sampler needs more VRAM than Sobol.
Re: Lamps
B.Y.O.B. wrote: Tue Jan 23, 2018 8:16 pm Check if your graphics card runs out of memory.
The problem is that currently not having the choice to select GPU device lead every opencl calculation to include intel integrated device. humm i guess .
Re: Lamps
You can switch off "Use CPUs" and it should only run on your graphics cards.
Re: Lamps
Only all installed discrete GPUs ?
Re: Lamps
I think all GPUs with OpenCL driver installed.
In the background, these checkboxes are setting the properties
opencl.cpu.use
and
opencl.gpu.use
See https://wiki.luxcorerender.org/LuxCore_ ... er_Engines
Re: Lamps
B.Y.O.B. wrote: Tue Jan 23, 2018 8:35 pm I think all GPUs with OpenCL driver installed.
opencl.cpu.use
and
opencl.gpu.use
So in my case intel IGP will run.
Re: Lamps
Sharlybg wrote: Tue Jan 23, 2018 8:22 pm Every opencl calculation to include intel integrated device. humm i guess .
Intel integrated GPU is ... not ... good, just don't use it, the are not designed for GPU computing. I assume BlendLuxCore doesn't yet support single OpenCL device selection, it is possible and I guess it is only matter of time before its arrive.
