No "latest build" for linux on git?
juangea
Post by juangea »
Hi there.
Since a few days ago I saw that there is no latest build for linux done, is something happening with it?
Thanks!
acasta69
Re: No "latest build" for linux on git?
Post by acasta69 »
Thanks for highlighting this.
It seems there is some problem when checking the Python version:
 * Checking python
 !!! Python major version '3' is required
cp: cannot stat 'target-64-sse2/LuxCore.tar.bz2': No such file or directory
mv: cannot stat 'target-64-sse2/LuxCore.tar.bz2': No such file or directory
Finishing: Building LuxCore
The available Python3 should be v3.6.9:
https://github.com/actions/virtual-envi ... nd-runtime
I should have fixed the problem.
juangea
Post by juangea »
Awesome, thanks!
juangea
Post by juangea »
The Linux BlendLuxCore build is not present again on Git
I always forget, it should now run.
juangea
Post by juangea »
Not a problem, I’ll ping here in case it happens again :)
juangea
Post by juangea »
@Dade the linux build again, it's not up :)
juangea wrote: Fri May 28, 2021 1:33 pm @Dade the linux build again, it's not up :)
It is not the usual stuff, something else has changed on Azure, I have to look into the problem.
juangea
Post by juangea »
Understood :)
