Rough/frosted glass
DavidF
Rough/frosted glass
Post by DavidF »
I think I have similar questions as forgeflow asked many years ago on the LuxRender forums (http://www.luxrender.net/forum/viewtopi ... =16&t=3252 ), i.e. why do objects using the rough glass shader appear darker when the roughness is increased?
Basically I am trying to create a material resembling frosted glass and I have done so by enabling the "Rough" option of the glass node. I expected that a higher roughness would generate a brighter surface (e.g. https://goo.gl/images/qEZvhD ), but instead the objects become dark. Any ideas why this happens or how I could create a better frosted glass material? I have attached the blend file I've been using for these tests.
Thanks in advance,
David
Roughness 0.02
Roughness 0.2
Frosted_glass.blend
(638.93 KiB) Downloaded 1072 times
Re: Rough/frosted glass
DavidF wrote: Wed May 16, 2018 9:58 am I think I have similar questions as forgeflow asked many years ago on the LuxRender forums (http://www.luxrender.net/forum/viewtopi ... =16&t=3252 ), i.e. why do objects using the rough glass shader appear darker when the roughness is increased?
I have the feeling it may be due to an increase of internal reflections, have you tried to increase the max. path depths ? I will do a test.
Ok, few notes about your scene:
- you are "1 1 1" values for the ground color, it is very unrealistic, you should use something more like "0.7 0.7 0.7" to physically plausible.
- you have a sky light source with gain "0.0 0.0 0.0" (outside a closed box). It is a noticeable waste rendering time.
- your max. depth setting are:
path.pathdepth.total = 7
path.pathdepth.diffuse = 5
path.pathdepth.specular = 6
6 is definitively to low for glass rendering. You should at least double the values (including "path.pathdepth.total").
However I think there is the same problem I fixed a while ago for (non-rough) glass. Try to switch between roughglass and normal glass; with very little roughness, they should look the same however rough glass is a LOT darker. I will check the code.
FiatLux
Post by FiatLux »
DavidF wrote: Wed May 16, 2018 9:58 amAny ideas why this happens?
It could be because the glass model.
This is the multi-scattering glass model that would fix the situation.
Here i made Glass-Volume Homogeneous Volume with Multiscattering on & Upped the Glass Material Roughness to 0.2.
Also, made ground Matte 0.76 White Value, rendered with BiDir (5000samples), denoiser used & added a bit of tonne mapping for better contrast.
Frosted_Glass-V.zip
(649.16 KiB) Downloaded 1130 times
DavidF
Post by DavidF »
Thanks for your comments!
kintuX wrote: Thu May 17, 2018 2:25 pm Here i made Glass-Volume Homogeneous Volume with Multiscattering on & Upped the Glass Material Roughness to 0.2.
How does the homogeneous volume with multiscattering work, doesn't that introduce scattering within the volume while frosted glass is mostly a clear volume with a microfaceted surface?
FiatLux wrote: Wed May 16, 2018 11:19 am
That's interesting. How does the current LuxCoreRender glass model compare to the models discussed in that work, i.e. the Smith microsurface model and the improved model including the multiscattering component?
