The caustics in 2.5 is a bit different from the caustic in 2.4
yikess
Post by yikess »
The left is 2.4 the right is 2.5.
I have tried 2.5beta and 2.5rc and the results are the same.
It seems that the caustics of 2.5 does not reflect on the object itself.Is there a way to fix it?
suzanne_caustics_test.blend
(876.34 KiB) Downloaded 211 times
Re: The caustics in 2.5 is a bit different from the caustic in 2.4
can you upload your blend ?
yikess
Post by yikess »
The blend file is uploaded,am I the only one having this problem? I thought there was no need to upload a blend file and that the problem could be reproduced in any blend file.
