Why is my Luxcore render look white?
frodehaugen93
Post by frodehaugen93 »
Why does my Luxcore render look white and not have any materials or textures??
Thanks for any help.
Re: Why is my Luxcore render look white?
LuxCore has its own material system (separate from Cycles). Have created and assigned material to any object ?
Also, pay attention to Error reports in Blender Render Properties and other helpful signs for better use.
Then you'll see and can simply press "Use Cycles Settings" but do note: pay further attention to details, not every Cycles feature and setting is supported in LuxCore. For those you will need to come up with workarounds.
Go through Documentation
https://wiki.luxcorerender.org/LuxCoreRender_Wiki
and Tutorials
DRAVIA Studio videos: https://www.youtube.com/c/DRAVIASTUDIO/videos
Crash course by djtutorials: https://youtu.be/QUtALzM6j5c
Do good, gather experience and skills.
Martini
Post by Martini »
If you're sure you have assigned LuxCore materials (or using Cycles material adapter), make sure you have not selected the Material Override on the View Layer panel.
You're probably looking for this button:
