Trying to make fog effect
- Leandro Oliveira
- Contact:
I´ve tried to make fog effect in my scene, but no success. I used this Dravia video (https://youtu.be/gvo9WLBqNVU) as a guide, but I can´t see the effect.
I´m running Lux 2.5 Daily Built from January 19th on Blender 2.91.
Scene attached.
Thanks,
Scene attached.
Thanks,
Re: Trying to make fog effect
Here:Leandro Oliveira wrote: Fri Jan 22, 2021 7:10 pm Hi,
Scene attached.
Thanks,
Mist Luxcore.blend
Note, Fog's Interior Volume is Corridor's Exterior Volume.
Take care
- Attachments
- Mistiqlc.blend
- (1.44 MiB) Downloaded 857 times
- Leandro Oliveira
- Contact:
Thank you, kintuX!
- Leandro Oliveira
- Contact:
@kintuX, I noted that you used a valor of 5 for priority, on Heterogenous Volume node. What is it for?
From documentation:Leandro Oliveira wrote: Mon Jan 25, 2021 11:44 pm @kintuX, I noted that you used a valor of 5 for priority, on Heterogenous Volume node. What is it for?
https://wiki.luxcorerender.org/LuxCoreR ... e_PriorityVolume Priority
Volumes have a priority setting, which is an integer number.
In regions where volumes overlap, the volume with highest priority is chosen and replaces all other volumes.
Hey, Leandro. You can also check this file with simple homo- and heterogen volume.
- Attachments
- Mist Luxcore.blend
- (1.4 MiB) Downloaded 795 times
- Leandro Oliveira
- Contact:
Thank you, kintuX!kintuX wrote: Tue Jan 26, 2021 8:15 amFrom documentation:Leandro Oliveira wrote: Mon Jan 25, 2021 11:44 pm @kintuX, I noted that you used a valor of 5 for priority, on Heterogenous Volume node. What is it for?
- Leandro Oliveira
- Contact:
Thank you very much, DionXein! I´m studying your file, too.DionXein wrote: Tue Jan 26, 2021 10:07 am Hey, Leandro. You can also check this file with simple homo- and heterogen volume.
Pay your attention to Camera's volume auto-detect. With premade volumes no need in Fog object. But in example from @kintuX Camera volume autodetects happens from Corridor exterior volume(because it have only inner normals direction).Leandro Oliveira wrote: Tue Jan 26, 2021 12:34 pm Thank you very much, DionXein! I´m studying your file, too.
- Leandro Oliveira
- Contact:
So, for atmospheric volumes, I have to use always a volume connected to the camera, right?DionXein wrote: Tue Jan 26, 2021 1:09 pmPay your attention to Camera's volume auto-detect. With premade volumes no need in Fog object. But in example from @kintuX Camera volume autodetects happens from Corridor exterior volume(because it have only inner normals direction).Leandro Oliveira wrote: Tue Jan 26, 2021 12:34 pm Thank you very much, DionXein! I´m studying your file, too.
