Studio-Scene now included with Luxrender
Theo_Gottwald
Post by Theo_Gottwald »
Looking through the Luxcore-Addon Folder, I found in:
AppData\Roaming\Blender Foundation\Blender\2.90\scripts\addons\BlendLuxCore-master\scripts\LOL
Two Blender files:
Studio.blend
and
Material_Thumbnails.blend
both maybe as good start for Beginners.
They do render fine. With CPU.
With GPU rendering i got first the error that some internal hardware attribute are 4 words and need be 5 words.
The i rendered the Material Thumbnail first, it took some minutes to compile the Kernel and and after that all works fine. :-).
Also in that folder there is Python Script "Render_Thumbnails.py" that leads here to an error:
  File "..\02_Luxrender Scenes\Studio\material_thumbnail.blend\Text", line 7, in <module>
ModuleNotFoundError: No module named 'BlendLuxCore'
Did the Module name change?
import bpy
import sys
from os import listdir
from os.path import isfile, join, basename, dirname, splitext
from mathutils import Vector, Matrix
from BlendLuxCore.utils.compatibility import run
def select(objects):
    bpy.ops.object.select_all(action='DESELECT')
    for obj in objects:
        obj.select_set(True)
def calc_bbox(context, objects):
    bbox_min = [10000, 10000, 10000]
    bbox_max = [-10000, -10000, -10000]
    deps = bpy.context.evaluated_depsgraph_get()
    for obj in objects:
        obj = obj.evaluated_get(deps)
        bbox_corners = [obj.matrix_world @ Vector(corner) for corner in obj.bound_box]
        for corner in bbox_corners:
            bbox_min[0] = min(bbox_min[0], corner[0])
            bbox_min[1] = min(bbox_min[1], corner[1])
            bbox_min[2] = min(bbox_min[2], corner[2])
            bbox_max[0] = max(bbox_max[0], corner[0])
            bbox_max[1] = max(bbox_max[1], corner[1])
            bbox_max[2] = max(bbox_max[2], corner[2])
    return (bbox_min, bbox_max)
def render_material_thumbnail(assetname, blendfile, thumbnail, samples):
    context = bpy.context
    scene = context.scene
    name = basename(dirname(dirname(dirname(__file__))))
    user_preferences = context.preferences.addons[name].preferences
    with bpy.data.libraries.load(blendfile, link=True) as (mat_from, mat_to):
        mat_to.materials = mat_from.materials
    mat = mat_to.materials[0]
    context.view_layer.objects.active = bpy.data.objects['Luxball']
    bpy.data.objects['Luxball'].material_slots[0].material = mat
    context.view_layer.objects.active = bpy.data.objects['Luxball ring']
    bpy.data.objects['Luxball ring'].material_slots[0].material = mat
    run()
    context.scene.view_settings.gamma = 1
    context.scene.view_settings.exposure = 1
    context.scene.view_settings.look = 'Very High Contrast'
    context.scene.luxcore.halt.enable = True
    context.scene.luxcore.halt.use_samples = True
    context.scene.luxcore.halt.samples = int(samples)
    context.scene.render.image_settings.file_format = 'JPEG'
    context.scene.render.filepath = thumbnail
    bpy.ops.render.render(write_still=True)
def render_model_thumbnail(assetname, blendfile, thumbnail, samples):
    with bpy.data.libraries.load(blendfile, link=True) as (data_from, data_to):
        data_to.objects = [name for name in data_from.objects]
    # Add new collection, where the assets are placed into
    col = bpy.data.collections.new(assetname)
    # Add parent empty for asset collection
    main_object = bpy.data.objects.new(assetname, None)
    main_object.instance_type = 'COLLECTION'
    main_object.instance_collection = col
    # Objects have to be linked to show up in a scene
    for obj in data_to.objects:
        # Add objects to asset collection
        col.objects.link(obj)
    run()
    scene.collection.objects.link(main_object)
    bbox_min, bbox_max = calc_bbox(context, data_to.objects)
    print(bbox_min)
    print(bbox_max)
    bbox_center = 0.5 * Vector((bbox_max[0] + bbox_min[0], bbox_max[1] + bbox_min[1], 0))
    scale_size = 2 * max(abs(bbox_max[0] - bbox_min[0]), abs(bbox_max[2] - bbox_min[2]))
    background = [
        bpy.data.objects['Camera'],
        bpy.data.objects['Stage'],
        bpy.data.objects['Left Area'],
        bpy.data.objects['Right Area'],
        bpy.data.objects['Room'],
        bpy.data.objects['Top Area'],
        bpy.data.objects['Backlight Area']]
    camera = bpy.data.objects['Camera']
    select(background)
    context.scene.tool_settings.transform_pivot_point = 'CURSOR'
    bpy.ops.transform.resize(value=(scale_size, scale_size, scale_size), center_override=(0.6, 0, 0))
    camera.location.z = 0.5 * abs(bbox_max[2] - bbox_min[2])
    main_object.empty_display_size = 0.5 * max(bbox_max[0] - bbox_min[0], bbox_max[1] - bbox_min[1],
    main_object.location = (0.6, 0, 0)
    main_object.rotation_euler = (0, 0, 0)
    main_object.empty_display_size = 0.5*max(bbox_max[0] - bbox_min[0], bbox_max[1] - bbox_min[1], bbox_max[2] - bbox_min[2])
    col.instance_offset = bbox_center
    bpy.ops.render.render(write_still = True)
argv = sys.argv
argv = argv[argv.index("--") + 1:]
blendfile = argv[0]
assetname = splitext(basename(argv[0]))[0]
thumbnail = join(dirname(dirname(argv[0])), 'preview', 'full', 'local', assetname + ".jpg")
samples = argv[1]
type = argv[2]
if type == 'model':
elif type == 'material':
Re: Studio-Scene now included with Luxrender
These are internal files used for asset thumbnail creation for the LuxCore Online Library.
They are not expected to work outside of their intended context.
You are probably calling the script from the wrong place.
