Animation Node Bug
Animation Node Bug
I'm running into an issue currently with blender 2.83/2.9 + 2.5 combo. When doing animation node tree are not animated. i have two file to reproduce the issue. Is someone else have that ?
the Bug is also reported on Blender Bug tracker but we don't clearly know where it come from : https://developer.blender.org/T80780
Here are the files :
file 1 :
T76381.blend
(1.47 MiB) Downloaded 401 times
file 2 :
Test blend.blend
(3.21 MiB) Downloaded 448 times
Just open and run CTRL + F12. In file 1 the suzanne color should change. In file 2 the pool wave and caustic should be animated.
