when I try to take render it takes forever for my computer to take its render
Hi guys, I need your suggest about my render problem. I created a scene, inside of the scene i have just simple plane and glass bottle also i used Hdri map and all setup is basic. when I try to take render it takes forever for my computer to take its render and it shows that remaining time is unknown. the version of the Blender 2.83. I would be more than happy, if you help me out for this issue.
Re: Blend Luxcore not so responsive during rendering
This is likely to be the first and only-once GPU kernel compilation, it takes about 90secs on a fast CPU, what GPU/CPU do you have ?biperiden wrote: Thu Jul 02, 2020 9:19 pm Hi guys, I need your suggest about my render problem. I created a scene, inside of the scene i have just simple plane and glass bottle also i used Hdri map and all setup is basic. when I try to take render it takes forever for my computer to take its render and it shows that remaining time is unknown. the version of the Blender 2.83. I would be more than happy, if you help me out for this issue.
- Theo_Gottwald
Re: when I try to take render it takes forever for my computer to take its render
Rendering Images with very high resolution like 10000x8000 Luxrender is very unresponsive. Also compared with other renderers.
If i would be a programmer, i would say "It needs some DoEvents()" somewhere.
In short: The higher the resolution the longer you have to wait bevor you can change the size of the render-window or scroll in and out.
It does NOT need any dedicated test-scene. Is like that with ANY Scene. Just render it with a very high resolution.
I am right now rendering in Tiled-Mode.Its not responsive.
