Suggested Value Clamp
Post by Racleborg »
Hi
I appear to be getting some extreme values when setting World to sky with a value of 1(even with values of .01 it's way too bright). The view attached is with Camera Auto Brightness switched on and a gain value of .5. If Auto brightness is switched off then there is complete blow out in the preview.
You can see in the attached image that the suggested clamp value is extreme
I'm almost certainly doing something very wrong because the renders that I have seen on this forum, by other members, are absolutely fantastic!
Thanks for any help
Re: Suggested Value Clamp
Post by Racleborg »
...I've created a new Blend file and copied the objects into it to see what happens.
The default gain for the camera is .5, but if I set this to 0 then there is no more blow-out, but the suggested clamp value still appears extreme? (attached)
Thanks
extreme clamp.PNG (3.47 KiB) Viewed 4782 times
The clamp value is expressed absolute terms (i.e. done before tone mapping) so all tone mapping settings have no effect at all.
The suggested clamping value is currently base on just the average luminance of the image and when the image includes a directly visible sky, it is apparently blown out. This is something we need too look into.
Anyway, you can just ignore the suggested value and do some test with an hand set value (the suggested value would be a base line where to start from anyway, you have to tune the value according your taste).
Post by Racleborg »
That's great. Thank you for your help.
