Error: "not enough values to unpack (expected 3, got 2)"
Theo_Gottwald
Post by Theo_Gottwald »
Using blender 2.90 Alpha and the newest daily build.
Viewport Renderer does not work at all.
Re: Error: "not enough values to unpack (expected 3, got 2)"
Blender v2.90 ?
Only stable official Blender releases are supported.
Theo_Gottwald
Ok, thank you, that is currently 2.82a then i will try with this one.
Ok, the first try was positive, looks like it works with 2.82a
Thanks for the hint.
https://www.blender.org/download/
Post by marcatore »
I had some of that error in a scene using blender 2.83 beta.
Check if you have hair particles and try to disable from the rendering.
In my cases it was the particle.
I've fixed redoing the UV's and check materials and other settings like Lux Hair ones.
Theo_Gottwald
Strange things happen. After it worked with 2.82a, it seems now it also works with 2.90 ...
I did not change any settings.
