Blurred shadow reflection[solved]
Noah_
Post by Noah_ »
I don't know if it is an error or if the caches are incorrectly configured
untitled.blend
(805.46 KiB) Downloaded 336 times
Full Hybrid Back/Forward path tracing - I don't like clamping - Bidir it's great but very slow - I have 4096 MiB de Vram and I want to cry.
Re: Blurred shadow reflection
I just tried with the three settings increased as shown attached. Not sure if all of them are needed, or to be increased that much...
Didn't take noticably longer to pre-compute the cache, but the probelm's gone and the rendering also clears with MUCH fewer samples.
Noah_
Post by Noah_ »
It worked!
30 is not much? the precache doesn't take that long
Thanks CodeHD! :D
Re: Blurred shadow reflection[solved]
Shadow does OK. It's caustic in reflection that's spilling over, so Caustic Light Cache / Lookup Radius of 1cm is your solution ;)
Also, use thickness/solidify your geo in future to prevent other issues - while modeling have physical correctness in mind 8-)
