Slow pointiness shape computation
Topic split from viewtopic.php?f=4&t=1935
Have the same issue with 2.4 master on viewport RT cpu.
Pretty simple scene. Cpu stay at 100% without loading viewport render.
After a long 5mn wait viewport switch from solid to render mode.
Re: Luxcore is very slow and freezes
Sharlybg wrote: Tue Mar 24, 2020 6:20 pm Have the same issue with 2.4 master on viewport RT cpu.
Sounds like first-time kernel compilation for OpenCL viewport, but you say you are using CPU as device?
Can you upload a scene that shows the issue?
Is it only the startup time that's long, or is the interface sluggish even after the render has started, as reported in the first post?
Oscar9531 wrote: Tue Mar 24, 2020 6:24 pm the same for me, it is very slow to work interactively
Here is the scene. i know why it is like that. if you reduce subsurf to 3 or 4 you can work. but at 6 it Bye bye :roll:
Lux_Shader_Ball - Copie.blend
(841.59 KiB) Downloaded 564 times
Sharlybg wrote: Wed Mar 25, 2020 9:02 am Here is the scene. i know why it is like that. if you reduce subsurf to 3 or 4 you can work. but at 6 it Bye bye :roll:
It uses the Pointiness shape, is it intended ? Indeed, it is very slow, it has to recompute pointiness each time.
Yes i'm in process to make a new tutorial with it. And cycles is working fine with it even at 6 level subsurf.
Are you using pointiness also with Cycles?
I have accelerated the pointiness computation quite a bit in the latest builds, not sure if you're using that.
However, the Cycles implementation is still faster, which might become noticeable on very heavy meshes.
(The reason being, from what I can see, that LuxCore needs to build edge information, while Cycles uses the raw Blender mesh which still has edge information).
Yes of course.
why can't we do the same ? any blender API limitation.
It is the same for any geometry transformation (i.e. pointiness, displacement, etc.) and it always been like this.
P.S. It is likely to be not the topic of this thread, I have the feeling people were talking of a different type of problem.
Great job mate just instal the last build from both Luxcore and blendluxcore. it work great thank you thank you :)
Editing that mesh in Cycles (or even in the OpenGL viewport) is just as sluggish as in a Lux viewport render. This is simply due to the very high subdivisions and the time needed to compute them. The pointiness is just the icing on the cake.
Sharlybg wrote: Wed Mar 25, 2020 11:45 am
It would require a special pointiness precomputation just for Blender inside the Blender mesh transfer code. It's possible, but it would add a lot of complication and code duplication, which is why I'd like to avoid it (especially because the performance gain will be small).
