Texture view in Blender viewport
Re: Texture view in Blender viewport
Post by B.Y.O.B. » Tue Apr 03, 2018 3:29 pm
Sharlybg wrote:
Tue Apr 03, 2018 1:21 pm
There is a little problem with the new option "show in viewport" : It doesn't respect material face matching. I mean sometime when i hit this button the texture cover the entiere object.
Thanks for the report, I had not thought of this case.
I fixed it.
wasd
Post by wasd » Wed Jan 30, 2019 11:05 pm
I turned "Show in Viewport" on, now I can't disable it.
CPU Bidir + Metropolis | Log Power | Core i5-4570
Post by B.Y.O.B. » Wed Jan 30, 2019 11:31 pm
Go into edit mode, select all faces that you want to "reset", open an image editor and click on the "x" to the right of the currently selected image name.
wasd
Post by wasd » Fri Mar 08, 2019 12:18 am
Okaaay. Now I can't turn it on :?
I select all faces in edit mode, open file in image editor, press "Show in Viewport" button. Still no image in viewport.
In one file everything is fine, in another I can't see texture in viewport.
Dirty file curse again :cry:
UPD: Found it. It's Viewport/Shading/Textured Solid checkmark. Should be checked. Thanks, wasd.
