Linux Compiling LuxCore
I'm stuck with compiling on Linux with gcc at Boost failing to find Python.
Python3 and Python3 dev are installed and i have edited the build script at PYTHON_INCLUDE=`find /usr/include to correct location in kUbuntu 19.10
Re: Linux Compiling LuxCore
You can use something like:
What error do you get ?
cmake -DPYTHON_LIBRARY=/usr/lib/x86_64-linux-gnu/libpython3.7m.so -DPYTHON_INCLUDE_DIR=/usr/include/python3.7m .
Error log:
Where do i insert the cmake code line?
./boost/python/detail/wrap_python.hpp:50:11: fatal error: pyconfig.h: No such file or directory
50 | # include <pyconfig.h>
compilation terminated.
"g++" -m64 -pthread -O3 -finline-functions -Wno-inline -Wall -w -mtune=generic -mno-ssse3 -std=gnu++98 -mmmx -msse -msse2 -O2 -pipe -mfpmath=sse -fPIC -w -mtune=generic -mno-ssse3 -std=gnu++98 -mmmx -msse -msse2 -O2 -pipe -mfpmath=sse -fPIC -DBOOST_ALL_NO_LIB=1 -DBOOST_PYTHON_SOURCE -DBOOST_PYTHON_STATIC_LIB -DNDEBUG -I"." -I"/usr/local/include/python3.7" -c -o "bin.v2/libs/python/build/gcc-9.2.1/release/link-static/threading-multi/list.o" "libs/python/src/list.cpp"
...failed gcc.compile.c++ bin.v2/libs/python/build/gcc-9.2.1/release/link-static/threading-multi/list.o...
gcc.compile.c++ bin.v2/libs/python/build/gcc-9.2.1/release/link-static/threading-multi/dict.o
In file included from ./boost/python/detail/prefix.hpp:13,
from ./boost/python/dict.hpp:8,
from libs/python/src/dict.cpp:4:
"g++" -m64 -pthread -O3 -finline-functions -Wno-inline -Wall -w -mtune=generic -mno-ssse3 -std=gnu++98 -mmmx -msse -msse2 -O2 -pipe -mfpmath=sse -fPIC -w -mtune=generic -mno-ssse3 -std=gnu++98 -mmmx -msse -msse2 -O2 -pipe -mfpmath=sse -fPIC -DBOOST_ALL_NO_LIB=1 -DBOOST_PYTHON_SOURCE -DBOOST_PYTHON_STATIC_LIB -DNDEBUG -I"." -I"/usr/local/include/python3.7" -c -o "bin.v2/libs/python/build/gcc-9.2.1/release/link-static/threading-multi/dict.o" "libs/python/src/dict.cpp"
...failed gcc.compile.c++ bin.v2/libs/python/build/gcc-9.2.1/release/link-static/threading-multi/dict.o...
gcc.compile.c++ bin.v2/libs/python/build/gcc-9.2.1/release/link-static/threading-multi/long.o
from ./boost/python/long.hpp:8,
from libs/python/src/long.cpp:5:
"g++" -m64 -pthread -O3 -finline-functions -Wno-inline -Wall -w -mtune=generic -mno-ssse3 -std=gnu++98 -mmmx -msse -msse2 -O2 -pipe -mfpmath=sse -fPIC -w -mtune=generic -mno-ssse3 -std=gnu++98 -mmmx -msse -msse2 -O2 -pipe -mfpmath=sse -fPIC -DBOOST_ALL_NO_LIB=1 -DBOOST_PYTHON_SOURCE -DBOOST_PYTHON_STATIC_LIB -DNDEBUG -I"." -I"/usr/local/include/python3.7" -c -o "bin.v2/libs/python/build/gcc-9.2.1/release/link-static/threading-multi/long.o" "libs/python/src/long.cpp"
...failed gcc.compile.c++ bin.v2/libs/python/build/gcc-9.2.1/release/link-static/threading-multi/long.o...
gcc.compile.c++ bin.v2/libs/locale/build/gcc-9.2.1/release/link-static/threading-multi/util/gregorian.o
gcc.compile.c++ bin.v2/libs/python/build/gcc-9.2.1/release/link-static/threading-multi/tuple.o
from ./boost/python/tuple.hpp:8,
from libs/python/src/tuple.cpp:5:
"g++" -m64 -pthread -O3 -finline-functions -Wno-inline -Wall -w -mtune=generic -mno-ssse3 -std=gnu++98 -mmmx -msse -msse2 -O2 -pipe -mfpmath=sse -fPIC -w -mtune=generic -mno-ssse3 -std=gnu++98 -mmmx -msse -msse2 -O2 -pipe -mfpmath=sse -fPIC -DBOOST_ALL_NO_LIB=1 -DBOOST_PYTHON_SOURCE -DBOOST_PYTHON_STATIC_LIB -DNDEBUG -I"." -I"/usr/local/include/python3.7" -c -o "bin.v2/libs/python/build/gcc-9.2.1/release/link-static/threading-multi/tuple.o" "libs/python/src/tuple.cpp"
...failed gcc.compile.c++ bin.v2/libs/python/build/gcc-9.2.1/release/link-static/threading-multi/tuple.o...
gcc.compile.c++ bin.v2/libs/python/build/gcc-9.2.1/release/link-static/threading-multi/module.o
from ./boost/python/scope.hpp:8,
from libs/python/src/module.cpp:9:
"g++" -m64 -pthread -O3 -finline-functions -Wno-inline -Wall -w -mtune=generic -mno-ssse3 -std=gnu++98 -mmmx -msse -msse2 -O2 -pipe -mfpmath=sse -fPIC -w -mtune=generic -mno-ssse3 -std=gnu++98 -mmmx -msse -msse2 -O2 -pipe -mfpmath=sse -fPIC -DBOOST_ALL_NO_LIB=1 -DBOOST_PYTHON_SOURCE -DBOOST_PYTHON_STATIC_LIB -DNDEBUG -I"." -I"/usr/local/include/python3.7" -c -o "bin.v2/libs/python/build/gcc-9.2.1/release/link-static/threading-multi/module.o" "libs/python/src/module.cpp"
...failed gcc.compile.c++ bin.v2/libs/python/build/gcc-9.2.1/release/link-static/threading-multi/module.o...
gcc.compile.c++ bin.v2/libs/python/build/gcc-9.2.1/release/link-static/threading-multi/import.o
from ./boost/python/ssize_t.hpp:9,
from ./boost/python/object.hpp:8,
from ./boost/python/import.hpp:8,
from libs/python/src/import.cpp:6:
"g++" -m64 -pthread -O3 -finline-functions -Wno-inline -Wall -w -mtune=generic -mno-ssse3 -std=gnu++98 -mmmx -msse -msse2 -O2 -pipe -mfpmath=sse -fPIC -w -mtune=generic -mno-ssse3 -std=gnu++98 -mmmx -msse -msse2 -O2 -pipe -mfpmath=sse -fPIC -DBOOST_ALL_NO_LIB=1 -DBOOST_PYTHON_SOURCE -DBOOST_PYTHON_STATIC_LIB -DNDEBUG -I"." -I"/usr/local/include/python3.7" -c -o "bin.v2/libs/python/build/gcc-9.2.1/release/link-static/threading-multi/import.o" "libs/python/src/import.cpp"
...failed gcc.compile.c++ bin.v2/libs/python/build/gcc-9.2.1/release/link-static/threading-multi/import.o...
gcc.compile.c++ bin.v2/libs/python/build/gcc-9.2.1/release/link-static/threading-multi/object_protocol.o
from ./boost/python/object_protocol.hpp:8,
from libs/python/src/object_protocol.cpp:6:
"g++" -m64 -pthread -O3 -finline-functions -Wno-inline -Wall -w -mtune=generic -mno-ssse3 -std=gnu++98 -mmmx -msse -msse2 -O2 -pipe -mfpmath=sse -fPIC -w -mtune=generic -mno-ssse3 -std=gnu++98 -mmmx -msse -msse2 -O2 -pipe -mfpmath=sse -fPIC -DBOOST_ALL_NO_LIB=1 -DBOOST_PYTHON_SOURCE -DBOOST_PYTHON_STATIC_LIB -DNDEBUG -I"." -I"/usr/local/include/python3.7" -c -o "bin.v2/libs/python/build/gcc-9.2.1/release/link-static/threading-multi/object_protocol.o" "libs/python/src/object_protocol.cpp"
...failed gcc.compile.c++ bin.v2/libs/python/build/gcc-9.2.1/release/link-static/threading-multi/object_protocol.o...
gcc.compile.c++ bin.v2/libs/locale/build/gcc-9.2.1/release/link-static/threading-multi/std/std_backend.o
gcc.compile.c++ bin.v2/libs/locale/build/gcc-9.2.1/release/link-static/threading-multi/shared/mo_lambda.o
gcc.compile.c++ bin.v2/libs/program_options/build/gcc-9.2.1/release/link-static/threading-multi/winmain.o
gcc.compile.c++ bin.v2/libs/program_options/build/gcc-9.2.1/release/link-static/threading-multi/split.o
gcc.compile.c++ bin.v2/libs/program_options/build/gcc-9.2.1/release/link-static/threading-multi/config_file.o
gcc.compile.c++ bin.v2/libs/program_options/build/gcc-9.2.1/release/link-static/threading-multi/variables_map.o
gcc.compile.c++ bin.v2/libs/locale/build/gcc-9.2.1/release/link-static/threading-multi/shared/message.o
gcc.compile.c++ bin.v2/libs/locale/build/gcc-9.2.1/release/link-static/threading-multi/std/numeric.o
gcc.compile.c++ bin.v2/libs/program_options/build/gcc-9.2.1/release/link-static/threading-multi/options_description.o
gcc.compile.c++ bin.v2/libs/locale/build/gcc-9.2.1/release/link-static/threading-multi/posix/numeric.o
gcc.compile.c++ bin.v2/libs/program_options/build/gcc-9.2.1/release/link-static/threading-multi/parsers.o
gcc.compile.c++ bin.v2/libs/program_options/build/gcc-9.2.1/release/link-static/threading-multi/cmdline.o
gcc.compile.c++ bin.v2/libs/program_options/build/gcc-9.2.1/release/link-static/threading-multi/value_semantic.o
...failed updating 7 targets...
...updated 6642 targets...
!!! Boost compilation failed
human@human:~/LinuxCompile$
They are additional parameters for when you call cmake. Important: erase CMakeCache.txt file if you are not starting from a fresh copy. Just try to do this after you get the error:
cd LuxCore
rm CMakeCache.txt
make -j 24
* 24 is the number of threads to use for the compilation.
It should work.
I removed the CMakeCache.txt and target folder and run:
cd LinuxCompile
./build-64-sse2 cmake -DPYTHON_LIBRARY=/usr/lib/x86_64-linux-gnu/libpython3.7m.so -DPYTHON_INCLUDE_DIR=/usr/include/python3.7m . make -j 16
Another error:
cd LinuxCompile
Another error:
human@human:~$ cd LinuxCompile
human@human:~/LinuxCompile$ ./build-64-sse2 cmake -DPYTHON_LIBRARY=/usr/lib/x86_64-linux-gnu/libpython3.7m.so -DPYTHON_INCLUDE_DIR=/usr/include/python3.7m . make -j 16
*** BUILDING FOR X86-64 (SSE2) ***
* LuxCore static enabled
* OpenCL enabled
* Using GCC compiler
* Checking distfiles
boost_1_67_0.tar.gz
bzip2-1.0.6.tar.gz
c-blosc-1.17.1-bin.tgz
embree-3.2.4.x86_64.linux.tar.gz
freetype-2.4.11.tar.bz2
ilmbase-2.2.0.tar.gz
jpegsrc.v6b.tar.gz
libpng-1.5.26.tar.xz
oidn-1.0.0.x86_64.linux.tar.gz
oiio-Release-1.8.11.tar.gz
openexr-2.2.0.tar.gz
qt-5.12.2.tar.gz
tbb2018_20180312oss_lin.tgz
tiff-4.0.3.tar.gz
xz-5.0.5.tar.xz
zlib-1.2.8.tar.gz
* Done checking distfiles
* Checking target tree
* Target tree is absent, populating
mkdir: created directory '/home/human/LinuxCompile/target-64-sse2'
mkdir: created directory '/home/human/LinuxCompile/target-64-sse2/bin'
mkdir: created directory '/home/human/LinuxCompile/target-64-sse2/include'
mkdir: created directory '/home/human/LinuxCompile/target-64-sse2/lib'
mkdir: created directory '/home/human/LinuxCompile/target-64-sse2/share'
* Done creating target tree
* Checking libstdc++
* Library symlink is missing, attempting to figure out the proper location
* Found at /usr/lib/gcc/x86_64-linux-gnu/9/libstdc++.a
* Updating symlink
'/home/human/LinuxCompile/target-64-sse2/lib/libstdc++.a' -> '/usr/lib/gcc/x86_64-linux-gnu/9/libstdc++.a'
* Done checking libstdc++
* Checking python
* Found at /usr/lib/x86_64-linux-gnu/libpython3.7m.a
* Updating symlink
'/home/human/LinuxCompile/target-64-sse2/lib/libpython3.7.a' -> '/usr/lib/x86_64-linux-gnu/libpython3.7m.a'
* Done checking python
* Checking LuxMark scenes
* Done LuxMark scenes
* Prechecks completed
* Using Python library path: /home/human/LinuxCompile/target-64-sse2/lib/libpython3.7.a
* Using Python include path: /usr/include/x86_64-linux-gnu/python3.7m
* Installing STANDALONE version at /home/human/LinuxCompile/target-64-sse2/cmake
cp: cannot stat 'cmake/lib/pyluxcoretools.zip': No such file or directory
cp: cannot stat 'cmake/bin/luxcoreui': No such file or directory
cp: cannot stat 'cmake/lib/*.so': No such file or directory
cp: cannot stat '/home/human/LinuxCompile/target-64-sse2/lib/libOpenImageDenoise.so.0': No such file or directory
cp: cannot stat '/home/human/LinuxCompile/target-64-sse2/lib/libembree3.so.3': No such file or directory
cp: cannot stat '/home/human/LinuxCompile/target-64-sse2/lib/libtbb.so.2': No such file or directory
cp: cannot stat '/home/human/LinuxCompile/target-64-sse2/lib/libtbbmalloc.so.2': No such file or directory
cp: cannot stat 'cmake/README.md': No such file or directory
cp: cannot stat 'cmake/COPYING.txt': No such file or directory
cp: cannot stat 'cmake/AUTHORS.txt': No such file or directory
cp: cannot stat 'cmake/scenes/cornell/cornell.cfg': No such file or directory
cp: cannot stat 'cmake/scenes/cornell/cornell.scn': No such file or directory
cp: cannot stat 'cmake/scenes/cornell/Khaki.ply': No such file or directory
cp: cannot stat 'cmake/scenes/cornell/HalveRed.ply': No such file or directory
cp: cannot stat 'cmake/scenes/cornell/DarkGreen.ply': No such file or directory
cp: cannot stat 'cmake/scenes/cornell/Grey.ply': No such file or directory
cmake/
cmake/scenes/
* Installed successfully to /home/human/LinuxCompile/target-64-sse2/cmake
* DONE
Uh ? No, you run:
cd LinuxCompile
./build-64-sse2 <name of the LuxCore directory>
[you get an error]
cd <name of the LuxCore directory>
rm CMakeCache.txt
make -j 24
human@human:~/LinuxCompile$ cd opencl
human@human:~/LinuxCompile/opencl$ rm CMakeCache.txt
rm: cannot remove 'CMakeCache.txt': No such file or directory
human@human:~/LinuxCompile/opencl$ cmake -DPYTHON_LIBRARY=/usr/lib/x86_64-linux-gnu/libpython3.7m.so -DPYTHON_INCLUDE_DIR=/usr/include/python3.7m .
CMake Error: The source directory "/home/human/LinuxCompile/opencl" does not appear to contain CMakeLists.txt.
Specify --help for usage, or press the help button on the CMake GUI.
human@human:~/LinuxCompile/opencl$ make -j 16
make: *** No targets specified and no makefile found. Stop.
Why do you bother to compile it when there is a nightly build almost every day ?
I decided to get azurepipeline going for macos since i was tiered of compiling every day
You will get a highly optimized build for linux ! just by downloading.
If you want to learn it you have to dive into how the terminal works first. It would be so much easier to help you then.
This way we can only guess which is hard to follow. Try to find some basic tutorial.
Don't get me wrong you are more then welcome here.
portfolio http://q3de.com/
