Remap node
Egert_Kanep
Remap node
Post by Egert_Kanep »
Let's say I have a gradient with values from 0-10 and use remap node with input and output min0 max1. Is it going to limit the output gradient between 0-1?
Re: Remap node
Yes, because I implemented it with clamping: https://github.com/LuxCoreRender/LuxCor ... ap.cpp#L83
However, the formula performing the actual remapping might work without clamping: https://github.com/LuxCoreRender/LuxCor ... ils.h#L331
I can remove the clamping if you want.
Re: Remap node
B.Y.O.B. wrote: Tue Jan 21, 2020 11:06 am Yes, because I implemented it with clamping: https://github.com/LuxCoreRender/LuxCor ... ap.cpp#L83
I believe it would be best, if it could be made as an optional on/off checkbox?
Egert_Kanep
Re: Remap node
If output max/min remaps the input to specified range then I don't see how clamping here would help anymore. It is just that sometimes I feel like remap node did not behave like I expected. It felt like sone values went under 0 and over 1, but I don't have any specific examples yet
