Doing proper SSS
Egert_Kanep
Doing proper SSS
Post by Egert_Kanep »
I have been trying to achieve some kind of sss feel with glossy translucent and volumes. I looked at the example in the wiki, but am unable to achieve same or even similar result.
The only way I have gotten any subsurface look is by lowering the opacity of translucent materials. Does anyone have any setup or method for achieving good looking sss?
Also would it be possible to have volumes as separate aov?
Fox
Re: Doing proper SSS
Post by Fox »
If my memory serves me correct, the reflection color has to be close to black (dark gray), then the glossy translucent is more translucent and gives the look what volume have you set up for it.
Fox
Post by Fox »
Seems like mix with rough glass can have more translucency.
sss.7z
(75.92 KiB) Downloaded 305 times
Egert_Kanep
I basically copied wiki settings but result is very different
https://wiki.luxcorerender.org/Subsurface_Scattering
Egert_Kanep
I used matte translucent for this test. Does this look correct?
matte+volume, matte with red translucency, pure volume
Egert_Kanep
some more experiments with sss. This time I tried to use color at depth node as scatter color parameter for volume. This way I can have variable volume ''density'' in the mesh
wasd
Post by wasd »
Egert_Kanep wrote: Mon Dec 23, 2019 4:10 pm I used matte translucent for this test. Does this look correct?
Nope, it doesn't.
I am just trying the same – make at least moderately correct looking human skin, but it seems current materials with volumes attached just don't make any sense. If they are physically based, I want to know on what physics.
