(Attached)
Latest Page missing
Re: Latest Page missing
Not sure if you should have /tag there. This works for me: https://github.com/LuxCoreRender/LuxCor ... ses/latest
Edit: or else there was a tag for latest and now it's been deleted
Yes, I think the address has changed.Edit: or else there was a tag for latest and now it's been deleted
This is what I was actually looking for:
https://github.com/LuxCoreRender/LuxCore
Thanks
It should be restored now, there has been a problem where the tag has been deleted and then not restored by a following release.
The currently available binaries are from yesterday morning.
https://github.com/LuxCoreRender/LuxCor ... tag/latest
Keep in mind that building is currently failing because the ongoing effort to build MacOS binaries on Azure too.acasta69 wrote: Tue Dec 17, 2019 9:09 am The currently available binaries are from yesterday morning.
Sure, that's the reason. For next builds, the previous daily release should be retained even in case of build failure.Dade wrote: Tue Dec 17, 2019 9:54 am Keep in mind that building is currently failing because the ongoing effort to build MacOS binaries on Azure too.
In a while there could be one more manual restore to be done, though.
Oh that's what i thought yesterday ... if it compiles ... will it be published ??
Still i have to figure out alot on how to make a usabel package .. so from my side there is no need to publish anything.
Can i access the built files ??? in order to test them ??
portfolio http://q3de.com/
