LuxCoreRender Caustics + Cycles
stanland
Post by stanland »
I would like to mix cycles render and lux caustics, what is the right way to get caustics from Lux? Here is the (yafaray) version https://www.youtube.com/watch?v=vZ7EtyhGeWo
stanland
Re: LuxCoreRender Caustics + Cycles
Post by stanland »
How can i also get a good sharp caustics in reflections? I have problems to do so.
Lux_caustics.blend
(1.31 MiB) Downloaded 586 times
stanland wrote: Fri Nov 15, 2019 12:12 pm How can i also get a good sharp caustics in reflections? I have problems to do so.Lux-Custics.jpg
They are called SDS paths (i.e. Specular-Diffuse-Specular paths) and are very hard to impossible to render even for normal BiDir. They require this feature: viewtopic.php?f=5&t=1449
Short version: you need to use a v2.3 automatic build and to enable caustic cache too.
stanland wrote: Fri Nov 15, 2019 12:06 pm I would like to mix cycles render and lux caustics, what is the right way to get caustics from Lux? Here is the (yafaray) version https://www.youtube.com/watch?v=vZ7EtyhGeWo
There is a trick you can use:
- use PATHCPU;
- enabled light tracing and set the partition between light and eye tracing to do only light tracing.
The rendering will include now only the caustics and should be easy to mix with Cycles output.
Note: it will miss the SDS path contribution I was talking in my previous post. There isn't currently a way to do an SDS path only rendering.
stanland
Post by stanland »
When official v2.3 will be out?
Thanks for the tips! :)
stanland wrote: Fri Nov 15, 2019 12:46 pm
I hope before the end of the year but don't hold your breath :!:
However automatic build is quite stable so you could give it a spin.
