Just why it doesn't work if the "Cube" volume object totally surround the camera ?
Working
not Working
blendfile
Air Dust
- Egert_Kanep
Re: Air Dust
Probably interior and exterior volume are not defined for objects. Attached fixed blend conf
- Attachments
- dust air_edit.blend
- (751.95 KiB) Downloaded 187 times
Re: Air Dust
Thanks you for the help. So everything have to be correctly setup manually like you did.I can understand the logic behind.Egert_Kanep wrote: Wed Oct 23, 2019 1:49 pm Probably interior and exterior volume are not defined for objects. Attached fixed blend conf
So now why my initial method is working ? i don't know
What is the limitation if it is a bad method ? don't know .
Really thaks you for the help.
Re: Air Dust
You have to set the camera or world volume.Sharlybg wrote: Wed Oct 23, 2019 2:53 pmThanks you for the help. So everything have to be correctly setup manually like you did.I can understand the logic behind.Egert_Kanep wrote: Wed Oct 23, 2019 1:49 pm Probably interior and exterior volume are not defined for objects. Attached fixed blend conf
Re: Air Dust
Set as same as my cube volume or a new volume ("air") ? anyway i've done both and it doesn't work.You have to set the camera or world volume.
tried Both
- Egert_Kanep
Re: Air Dust
Did you also define ext volume for your room object?
Re: Air Dust
No because that way it will be just replicating your working method. What i want to understand before Dade answer is why my first method work. ( No need to define room and camera volume. just put camera a bit outside of the volume).
Want to know why this one work.
- Egert_Kanep
Re: Air Dust
I think because by default camera assumes air to be ext interior and you view into the fog, not inside it. I might be wrong tough.
- FarbigeWelt
- Contact:
Re: Air Dust
Given the fact that your a very experienced user, your question should weigh a lot more.Sharlybg wrote: Wed Oct 23, 2019 4:03 pmNo because that way it will be just replicating your working method. What i want to understand before Dade answer is why my first method work. ( No need to define room and camera volume. just put camera a bit outside of the volume).
I guess there is an issue or at least an illogical behavior in the handling of volumes. Not only the camera omits scattering volume but also light sources depend on location, i.e. under some circumstances the beam is visible in the scattering volume if the light source is placed outside the volume but the beam is not visible if the light source is placed in the volume, e.g. laser. Strange enough, the beam gets visible after reflection by a mirror. (At least I observed these effects in LuxCoreRender V2.2.)
Re: Air Dust
Camera volume does not work.Dade wrote: Wed Oct 23, 2019 3:17 pmYou have to set the camera or world volume.Sharlybg wrote: Wed Oct 23, 2019 2:53 pmThanks you for the help. So everything have to be correctly setup manually like you did.I can understand the logic behind.Egert_Kanep wrote: Wed Oct 23, 2019 1:49 pm Probably interior and exterior volume are not defined for objects. Attached fixed blend conf
