Low discrepancy triangle light sampling
alpistinho
Post by alpistinho »
I have implemented a new technique for sampling triangles that should provide better results on them.
This is based (copied) in https://pharr.org/matt/blog/2019/02/27/ ... ing-1.html
The improvement should be most visible in scenes dominated by direct light.
Please give it a spin and keep a close eye for any issues ;)
At 4 samples/pixel:
before:
after:
At 16 samples/pixel:
before:
after:
happyboy
Re: Low discrepancy triangle light sampling
Post by happyboy »
alpistinho wrote: Wed Oct 09, 2019 2:10 pm Please give it a spin and keep a close eye for any issues ;)
The improvement is obvious! Thanks!
This is going to make product viz a lot faster. Thanks.
Thanks for this very welcome improvement!
It is activated by default or something special is needed in blendluxcore for that one ?
alpistinho
Sharlybg wrote: Fri Oct 11, 2019 7:05 pm It is activated by default or something special is needed in blendluxcore for that one ?
It replaces the old code, so nothing is needed.
I don't think the difference is that big outside a few specific cases, so you might not be able to promptly see the difference.
