Hotel pool area concept design
Personal work, rendered with early 2.3 build for caustics
Re: Hotel pool area concept design
more
Quite awesome :mrgreen:
Great stuff, good choice of angles too.
With Hybrid + SDS-cache Dade has delivered another ingenious solution making things possible in short time that would've taken hours or days before.
(Time for 2.3alpha0 release I think :D )
Last edited by epilectrolytics on Thu Oct 03, 2019 1:32 pm, edited 1 time in total.
Really outstanding. Love the black marble material and of course the caustics in the water.
It would be awesome to have this as an example scene. :)
Can I add some of them to the gallery?
epilectrolytics wrote: Thu Oct 03, 2019 1:24 pm With Hybrid + SDS-cache Dade has delivered another ingenious solution making things possible in short time that would've took hours or days before.
There's no support for it in the Blender addon yet, I'll have to do that first.
B.Y.O.B. wrote: Thu Oct 03, 2019 1:29 pm There's no support for it in the Blender addon yet, I'll have to do that first.
Just take your time, we can use it via LuxCoreUI already :)
I guess you are a good photographer and observer. Your computer generated images look very realistic. This perfection grows from all the details even in small things like the bowls of fruits, the meals card, the welding traces of the bar chairs, the porous edge of launch tables, the ocean's waves, the palm trees, et cetera.
There is nothing missing but humans enjoying the place.
Great work! Congratulations!
:D
B.Y.O.B. wrote: Thu Oct 03, 2019 1:29 pm Really outstanding. Love the black marble material and of course the caustics in the water.
Sure you can add what you find suitable to the gallery, as an example scene it is pretty heavy and uses quite a bit of third party models and textures (mostly modified but still) so this could be a problem. I was constantly running out of Vram and shuffling things around to make it fit (But many texture were probably higher res than needed, while some not enough :oops: )
Dade wrote: Thu Oct 03, 2019 1:21 pm Quite awesome :mrgreen:
Thanks :mrgreen:
epilectrolytics wrote: Thu Oct 03, 2019 1:24 pm Great stuff, good choice of angles too.
Thanks, you can use this config (overwrite config.py in export folder of blendluxcore2.8 addon folder)
config.rar
(5.23 KiB) Downloaded 985 times
or manually add these lines (...photongi.caustic.... related) in the config.py
If you use some of the latest azure build that is...
