Hi guys,
This happened to me this morning.
I don't have the choice of Luxcore engine. Why?
Choice on the engine - LuxCore
Re: Choice on the engine - LuxCore
got the same before.
i had to reinstall with zip manually.
If you are using Windows 10 check if Windows update did not messed up your graphics drivers....just reinstall them. This helped me to solve the problem.
On the top it says "upgrade to 2.8x required", which means that you have the variant for Blender 2.79 installed.
Maybe you used the integrated updater? It will only work correctly in 2.80 from v2.2beta4 onwards, but v2.2beta4 has to be downloaded manually from here: https://github.com/LuxCoreRender/BlendLuxCore/releases.
Thanks for your answers.
The Window Update is disabled, so I don't think it was such a problem.
Version 2.79 no longer has it on the PC and I checked, it's the OpenCL version for 2.80.
Anyway now I try again to remove everything and reinstall the latest version.
Thanks again.
Thanks again.
Perfect! I solved with installation of latest build.zip!
Tnx a lot for your availability.
