Shadow catcher
Rivental1
Shadow catcher
Post by Rivental1 »
Hello. I have plane with shadow catcher material, and sphere on the top of this plane. In cycles, this plane reflected on the sphere, in luxcore no. Are there any way fix it?
Re: Shadow catcher
Rivental1 wrote: Sat Jul 20, 2019 2:21 pm I have plane with shadow catcher material, and sphere on the top of this plane. In cycles, this plane reflected on the sphere, in luxcore no.
LuxCore reflects what you see so the shadow catcher composition is correct also if you look at the mirror. From your description, the Cycles behavior looks just wrong (i.e. you see the plane on the reflection) but I'm not sure to understand how it works.
Can you post a LuxCore Vs Cycles image comparison to understand the difference ? Why you find the Cycles behavior useful ?
Rivental1
Re: Shadow catcher
Post by Rivental1 »
I gave bad example with that picture... sory. Of course with HDRI we dont need reflection from the plane, because we have reflection from the HDRI. But shadow cather being used, not only with HDRI, but with video and image background to...
This is example from corona
Corona has two mode of shadow catcher. With HDRI (when plane with shadow catcher material is absolutly invisible (exept shadows of course)) and Blackplate mode (for picture and video). In this mode corona projected piece of picture or video on the plane (with the same brightness) so, on the sphere we see reflection exectly from that piece of the  table, where sphere located. And i think it is very smart solution.
Сycles
In cycles, by default, plane is reflected on the sphere. But we can change this in one click on this checkbox.
Re: Shadow catcher
Rivental1 wrote: Sun Aug 04, 2019 8:37 am Corona has two mode of shadow catcher. With HDRI (when plane with shadow catcher material is absolutly invisible (exept shadows of course)) and Blackplate mode (for picture and video).
We support only the first mode at the moment but I now understand the point on the second mode.
andreysoul
Re: Shadow catcher
Post by andreysoul »
Hello! Is there a chance to implement a second shadowcatcher mode (with hdri)?
