Emission and Opacity: lower power?
marcatore
Post by marcatore » Tue Jul 09, 2019 2:57 pm
I'm always find a way to have a real "invisble" area lights to fake lighting for interiors rendering.
I've tested the opacity option and it should be perfect but I've seen that the mesh, with full opacity, seems to spread less ligh than an area light (or the same mesh with opacity at 0 ).
If you open the scene and measure the RGB values, the lights reflected on the ground are different: mesh with emission and opacity is 1/6 of the area light.
These two images for comparison with a glossy metal material.
Left: Emission material with Opacity = 0 | Right: Area Light
Left: Emission material with Opacity = 1 | Right: Area Light
Is it impossible to have, at the moment, the same result?
This is the scene if someone would play with it.
FakeLights.zip
(82.96 KiB) Downloaded 26 times
Re: Emission and Opacity: lower power?
Post by Dade » Wed Jul 10, 2019 8:56 am
This is due to the (lack of) MIS and it is expected but you are not using the tools in the way they are meant to be used. In this case, you should use the camera invisible object option to obtain the correct result:
If you don't want the are light shadow, use a point light source with radius > 0.0 (i.e. a not intersectable light source).
Back transparency is intended for objects enclosing a light source (but not emitting light their-self): viewtopic.php?f=5&t=984
P.S. I could fix the (lack of) MIS but it may be not worth the effort because, like I wrote, it is not the way intended to be used.
marcatore
Post by marcatore » Wed Jul 10, 2019 9:50 am
About the light shadow, yes I don't want it cause as I'm faking lighting using "big" area lights and obviously I'd like to have them completely hidden and a shadow will reveal the area light.
(My "wet" dream is to have the option to filter both specular and reflection visibility...additionally to direct visibility and shadows :D 8-) )
I've tried your suggestion to use a point light but this has many disadvantages like the shadow blurriness depends by the radius instead of the light distances from the objects and to have an area light shape I should, everytime, add a IES file to emit light from just one direction.
In my opinion, add MIS to an "invisbile" light it worths. I use everyday this kind of setup cause many time I don't have full lighting design and designers often can judge more easily a project with a more general lighting instead of full lighting setup. And.. last but not least, it's faster to add 20 area lights to illuminate 90square meters than take a full 3d model lamp, duplicate them at least 80 times and rotate everyone to make a diffused lighting.
In any case, the last word it's yours... I mean that as developer you're surely more entitled to estimate the effort to develop this and if this is something you want to develop. From your previous post it seems that you'd like to avoid but as you left open a door for this I've expressed my whis :)
Post by Dade » Wed Jul 10, 2019 3:08 pm
I may add the MIS support for a special case (and probably the only useful): when opacity is set to 0 (i.e. fully transparent like in your case). Adding full support for partially transparent objects is likely to be a pain.
P.S. I'm out of the town, I will check next week.
marcatore
Post by marcatore » Wed Jul 10, 2019 3:15 pm
It should be perfect!
Thanks in advance.
Post by Dade » Tue Jul 16, 2019 4:01 pm
Now totally and partially transparent light sources are rendered with the correct intensity (and MIS):
Post by B.Y.O.B. » Tue Jul 16, 2019 6:30 pm
Awesome, thank you!
marcatore
Post by marcatore » Wed Jul 17, 2019 7:18 am
Super!!!! Thank you very much!!
Is it already on the last build?
Post by Dade » Wed Jul 17, 2019 8:24 am
Yes, it should.
marcatore
Post by marcatore » Wed Jul 17, 2019 8:45 am
On daily builds page I can see "Dade916 released this 9 days ago · 3 commits to master since this release".
So, if I'm not wrong, it seems that the last build older than this new feature..or not?
