Is pausing rendering working for you guys?
Taka
Post by Taka »
I'm trying to use light groups feature to adjust lightings but I can't pause the rendering. My understanding is to adjust light groups, you hit "Render" then pause the rendering, correct? I believe it was working before but now it doesn't.
Re: Is pausing rendering working for you guys?
The pause button is in the toolshelf of the image editor (shortcut T), in the LuxCore category.
Is the button not working?
Taka
Post by Taka »
Hi B.Y.O.B.,
Thanks for your quick response! I'm trying with other files and with some it works, but others it wouldn't let me press the button.
Here is a simple scene that pause doesn't work.
LightGroupTest.blend
(736.08 KiB) Downloaded 646 times
You have the interface locked during render. You need to leave it unlocked.
Taka
Post by Taka »
I never knew such function exists! I guess I accidentally press it somewhere along.
Thank you so much for your help B.Y.O.B.!
