CPU BiDir broken or changed somehow?
:!: Look at this post and its animated gifs.
Lenses, CPU BiDir, different depths
Now look at this 'pale' image.
Lenses, CPU BiDir, depth 25
What is going on here :?:
Gems.zip
(879.76 KiB) Downloaded 150 times
Fox
Re: CPU BiDir broken or changed somehow?
Post by Fox »
You by mistake set the air ior to absorption slot, so it was at 1.5 for air, and cameras don't have exterior volume set.
Fox wrote: Wed Jun 05, 2019 11:50 am You by mistake set the air ior to absorption slot, so it was at 1.5 for air, and cameras don't have exterior volume set.
Wow! Thank you lot, what a crazy mistake. In this case I have to repeat the renders I posted lately. However, I wonder about the difference between openCL and BiDir and so on because it is the original file of first linked post. Well, it needs clarification that is clear now.
